โJul-11-2016 02:36 PM
โJul-12-2016 10:53 AM
mrkoje wrote:
What I understand that you are saying is that by taking a 12v battery and connecting it in parallel with another 12v battery that because of differences in the two (even if they are the same battery model) will only produce approximately 1.5x capacity instead of 2x that would be expected?
โJul-12-2016 10:08 AM
Matt_Colie wrote:Sam Spade wrote:mrkoje wrote:Matt_Colie wrote:
Please do not parallel 12V jars. Even if they were side by side on the assembly line, by the end of the third week, they will not like playing in parallel. If you are lucky, you end up with capacity * 1.7. It will more likely be 1.5.
Please explain ...
Please search a bit.
Gross oversimplification summary:
If the two are not perfectly matched, part of the capacity of the stronger one will be expended trying to charge the weaker one. And when charging, the weaker one will sap off more of the charge.
And if one should fail completely, disaster can occur.
The disaster is rare and I think his 1.7 estimate is closer until they get really old but 6 Volts in series really are better.
Sam,
Thanks for picking this up before I got back here. Yes, that may be a gross oversimplification, but if we explained it in more detail many eyes would glaze over. There are so many important variables, that it is difficult to get arms around, but please believe us.
I have always loved a line from the original Stargate. Colonel Jack Anderson (Richard Anderson) was listening as the tech-savey lady explained how something worked. At the end, he looked at her and said,"That was a complete waste of a perfectly good explanation."
โJul-12-2016 09:16 AM
Sam Spade wrote:Matt_Colie wrote:
They said that you really can't charge a battery too hard if you do not over voltage the charge.
This is true but it's a funny way to state it.
It's kind of like stating that water will not overflow out of a bucket if you don't put too much IN it. ๐
โJul-12-2016 09:11 AM
Please explain ...
โJul-12-2016 06:41 AM
โJul-12-2016 06:38 AM
Please explain ...
โJul-12-2016 06:34 AM
โJul-11-2016 11:27 PM
โJul-11-2016 06:04 PM
โJul-11-2016 03:31 PM
โJul-11-2016 03:16 PM
โJul-11-2016 03:13 PM
2oldman wrote:
Is this a real consideration? I mean, can a single small battery be harmed by say a, 100a charger?
โJul-11-2016 02:58 PM
โJul-11-2016 02:48 PM
