which grease for wheel bearings on tt
images
Large variety of grease available to repack wheel bearings, how do you choose.
The old standard is lithium but there is also a lot of synthetic in the market, are they any better.
Joe & Deb And A Senegal Parrot named Sunny
10 REPLIES 10
mike-s
time2roll wrote:
mobile 1 goes on mine for the highest dropping point spec.
If your hubs are getting that hot, you're doing it wrong.
amxpress
I’m a strong believer in using a quality synthetic grease.
Amsoil Synthetic Grease
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
Mortimer_Brewst
I use Mystic JT-6 Hi-Temp #2. I can get it in both a tube and a tub, so I don’t have to worry about incompatibility. It’s also Dexter approved.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
fj12ryder
Mine is pretty much whatever is in the grease gun at the time.
Howard and Peggy
"Don't Panic"
time2roll
mike-s
I just use the Valvoline red grease from my FLAPS. It's a lithium soap, I think.
azdryheat
My Chinese made bearings don't seem to care about the grease. I use a grease made for wheel bearings but not the high temp kind of grease.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
BB_TX
Lithium has proven itself. But main thing is make sure you do not mix grease types.
Iraqvet05
Who makes your axles? Dexter has a recommended list of grease on their website and Lippert may too.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
Lwiddis
If you repack yearly, a good practice, either will do IMO.
