โJul-31-2024 09:50 AM
How often do you repack the RV wheel bearings? I'm getting many different opinions on this question.
โSep-01-2024 11:34 AM
Not sure, but I think about every 2000 mi. or so. If you have Never Lube Axles or axles that have a zirk fitting be careful how much grease you use, as too much can get on your breaks. Be sure to take the pressure off the wheel by jacking the wheels up so you can spin the wheel and get the weight off.
โAug-31-2024 07:33 PM
I recently bought a used 2010 travel trailer, they, private party, told me it was in great condition and serviced annually. Owned by a senior widow. I checked it before buying it the best I could. They delivered it to me. Next weekend I gave it a more through check out. Found I needed 4 tires, Brakes, 12 volt house power repairs, Gas leaks repaired, Water leaks repaired. 30 amp house power repaired. My son and I have been fixing it since March and have most items repaired so it is usable. I plan an annual brakes and bearing inspections and grease bearings.
โAug-14-2024 11:53 AM
Thanks all. Appreciate the wisdom.
โAug-01-2024 01:36 PM
Every 6,000 miles which works out to about every 2 years.
โAug-01-2024 11:33 AM
I'm with Stircrazy on it being smart to have it done at least once initially so you know it's good.
โAug-01-2024 05:18 AM
every year I add new grease and force the old grease out. but I don't have to take them apart to do that.
โJul-31-2024 04:33 PM
Somewhere between 3 days and 30 years. ๐
Assuming it's done properly, it should be good for 20-30k miles but unlike a semi, most people only tow a couple thousand miles per year (if that), so they often revert to a time basis (annual, biannual, etc...) as it's easier to track but which is likely overkill as the grease doesn't go bad or pick up contaminants.
Result, you get recommendations that are all over the place. If you want something more definitive, look up the axle brand and they should have a recommendation online.
โAug-01-2024 05:23 AM
you would be surprized how dark and oxidized the grease is when I take the old stuff out at the biging on the season. I never used to repack them very often at all, but after having an incident with my brand new 5th wheel, never packed properly or enough at the factory, I just put new grease in every year now, takes me a hour or two and 30 bucks. I also now use a IR thermomitor intermittiantly to check running temps to hopefully catch a issue before it happens, so far no issues since I started doing that. I would recomend anyone buying a brand new trailer either service the berrings or get the dealership to do it as a condition of sale before it comes off the lot. as I found out the issue I had is actualy quite comon..
โAug-01-2024 02:38 PM
Big difference between bad/contaminated/worn out grease and never having been properly greased in the first place.
I agree with at least pulling and checking when you get a new trailer as you have no idea if the last guy did it right and I've heard stories of new trailers coming with no grease. And pulling the tires is most of the work, so once you have the tires off, may as well repack them.
I also have a habit of feeling the hubs for excess heat when we stop but even freshly repacked, I'm doing it.
No harm in doing it more often but really not needed.
โAug-02-2024 07:51 AM
oh I know I am probably a little overkill with once a year.. but when you get a berring that is glowing red 1/2 way home on your first trip you tend to watch them a little harder. that was a fun trip home, little short drives with cool down stops for 200 miles.
My first three trailers (old chalet, a tent trailer then a 28 foot trailer) I never checked them at all in 20 years they occupied, although I didn't have internet forums back then so there was nothing to make me paranoid ๐คฃ
if I had to pick a minimum I think I would do it every 3 years.. if the rv industry would switch over to cartrage bearings like most vehicles have you would never have to worry about it again.
โJul-31-2024 02:11 PM
I don't have a set time for mine. Probably every few years or so. My trailer probably gets pulled under a thousand miles a year. So in reality, I'm probably repacking every 2-3000 miles. This is way less than the 30,000 miles that my old cars wanted.
โJul-31-2024 12:03 PM
Annually
