Wheel bearing repacking
Ljava
How often do you repack the RV wheel bearings? I'm getting many different opinions on this question.
17 REPLIES 17
aftermath
I have mine done every 10,000 miles.  I purchased our 2006 Airstream in 2009 and took it to the Airstream Dealer and had them do the bearings and check the brakes first thing.  They told me that I didn't need to do this every year but should do it every 10 K miles.  This is what I have done and it has worked well for me.  Some people lube too often but most don't do it nearly enough.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
JDsdogs
Nomad II
Nomad II
I believe that maintenance should be based on miles traveled as well as time. If you are putting 10,000 miles on a year it's likely you need to repack. That being said, if you roll with about the maximum weight your axles will carry, more often may be necessary.  Sadly, while I was researching the purchase of my current TT, I found many trailers being sold that barely had enough axle under them carry them empty.
joelc
Not sure, but I think about every 2000 mi. or so.  If you have Never Lube Axles or axles that have a zirk fitting be careful how much grease you use, as too much can get on your breaks.  Be sure to take the pressure off the wheel by jacking the wheels up so you can spin the wheel and get the weight off.
its not a case of how much you use in a ezlube axel, its how you put it in, if you squirt it in to fast it can get out of the seals onto the breaks, and if your not spining the tire as you put it in it cound go throuhg the seals.  you do want to put lots, the ide is to force the old grease out into the center cup area around the grease nozel and clean that out.  that way you know you have fresh greese through out the berring.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
Tadsher
I recently bought a used 2010 travel trailer, they, private party, told me it was in great condition and serviced annually. Owned by a senior widow. I checked it before buying it the best I could. They delivered it to me. Next weekend I gave it a more through check out. Found I needed 4 tires, Brakes, 12 volt house power repairs, Gas leaks repaired, Water leaks repaired. 30 amp house power repaired. My son and I have been fixing it since March and have most items repaired so it is usable. I plan an annual brakes and bearing inspections and grease bearings.
Ljava
Thanks all. Appreciate the wisdom.
Every 6,000 miles which works out to about every 2 years.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
opnspaces
Navigator II
Navigator II
I'm with Stircrazy on it being smart to have it done at least once initially so you know it's good.
StirCrazy
Moderator
Moderator
every year I add new grease and force the old grease out.  but I don't have to take them apart to do that.
2016 Cougar 330RBK
valhalla360
Nomad III
Nomad III
Somewhere between 3 days and 30 years. 😉
Assuming it's done properly, it should be good for 20-30k miles but unlike a semi, most people only tow a couple thousand miles per year (if that), so they often revert to a time basis (annual, biannual, etc...) as it's easier to track but which is likely overkill as the grease doesn't go bad or pick up contaminants.
Result, you get recommendations that are all over the place. If you want something more definitive, look up the axle brand and they should have a recommendation online.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
you would be surprized how dark and oxidized the grease is when I take the old stuff out at the biging on the season.  I never used to repack them very often at all, but after having an incident with my brand new 5th wheel, never packed properly or enough at the factory, I just put new grease in every year now, takes me a hour or two and 30 bucks.  I also now use a IR thermomitor intermittiantly to check running temps to hopefully catch a issue before it happens, so far no issues since I started doing that.  I would recomend anyone buying a brand new trailer either service the berrings or get the dealership to do it as a condition of sale before it comes off the lot.  as I found out the issue I had is actualy quite comon..
2016 Cougar 330RBK
I did exactly that, had the dealer check and provide any maintenance needed as a condition of sale.
Big difference between bad/contaminated/worn out grease and never having been properly greased in the first place.
I agree with at least pulling and checking when you get a new trailer as you have no idea if the last guy did it right and I've heard stories of new trailers coming with no grease. And pulling the tires is most of the work, so once you have the tires off, may as well repack them.
I also have a habit of feeling the hubs for excess heat when we stop but even freshly repacked, I'm doing it.
No harm in doing it more often but really not needed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
oh I know I am probably a little overkill with once a year..  but when you get a berring that is glowing red 1/2 way home on your first trip you tend to watch them a little harder.  that was a fun trip home, little short drives with cool down stops for 200 miles.
My first three trailers (old chalet, a tent trailer then a 28 foot trailer) I never checked them at all in 20 years they occupied, although I didn't have internet forums back then so there was nothing to make me paranoid 🤣
if I had to pick a minimum I think I would do it every 3 years.. if the rv industry would switch over to cartrage bearings like most vehicles have you would never have to worry about it again.
2016 Cougar 330RBK
