โNov-25-2017 08:31 AM
โNov-26-2017 01:39 PM
wnjj wrote:MEXICOWANDERER wrote:
Wiper motors have battery power supplied directly to the motor as well as ignition power.
When the wiper switch is turned off, the battery power continues to supply the motor with power until the wipers arrive at their resting place. Inside the gearbox is a limit switch oriented to shut the wipers down when they reach the PARK position.
A broken limit switch inside the wiper gearbox would cause this. So would a fried wiper pigtail battery power terminal. There is no way to defeat the auto park feature except to turn the key off while the wipers are in action. So, the clue is to check battery voltage at the connector to the wipers. It's time to grab a 12-volt test light and access a factory wiring diagram. Blind parts replacement try-it-and-see is a poor diagnostic substitute.
Hey Mex, I think you contradicted yourself a bit. The wiper motor has switched power (from the wiper switch) and ignition power but nothing directly from the battery. That's how you can defeat parking, like you said, by turning the key off before they park.
Regardless, the park switch is almost certainly the problem and usually means buying a new wiper motor unless you're handy enough to take it apart and clean the contacts.
โNov-26-2017 01:33 PM
โNov-26-2017 01:26 PM
โNov-26-2017 09:04 AM
โNov-25-2017 03:59 PM
โNov-25-2017 02:54 PM
It's a limit switch over-ride. To test the "theory" yourself, grab a test light go to the wiper motor and stab wires or stick the probe into the connector block. Yes, chopping off the ignition switch does stop the motor.
Shut off the switch when wipers are in motion. They stop. Shut off the wiper switch then turn the key back on. The wipers park with the wiper switch turned off.
Many switch/park motors operate with a battery hot going into the motor. Then a "relay trigger" comes from the wiper switch to a genuine relay. This powers the wiper motor. Shut off the switch and the relay plays dead. Something needs to over-ride the relay that now has no power to the coil nor going through the power points. The battery voltage only powers the wiper motor until the cam opens the limit switch contacts. The relay over-rides the limit switch - when key is on and relay is operating. Yes this means 2 fused circuits. One for power, the other for the switch.
The test light will reveal all ๐
โNov-25-2017 02:21 PM
โNov-25-2017 01:01 PM
โNov-25-2017 11:59 AM
โNov-25-2017 10:41 AM
โNov-25-2017 09:46 AM
โNov-25-2017 09:25 AM
โNov-25-2017 08:59 AM
