Lost power to 3 outlets
carjockie
i lost power to 3 electrical outlet, check the ground fault but that didn't power the outlets. Check the circuit breakers and they are on on, any other suggestion would be appreciated. Right now I have a double male supplying power to the three outlets. Is it possible I've have a broken wire?
โš Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
16 REPLIES 16
DReisinger
Do you have power on the load side of the GFCI
carjockie
Thanks to all that replied. Found a severed wire that was caught between the wall and slide, reconnected and it works fine, thanks again.
rhagfo
beemerphile1 wrote:
ScottG wrote:
time2roll wrote:
Cut the deadman cord in half and throw it away.
X2!
This is not the way to do things.
Please, please, please, get rid of that suicide cord before you kill yourself or someone else.
Wow, read the OPโ€™s post three times and eyes were pulled away from the dangerous last sentence by the moderators bold Red notice.
Yes dump the deadman cord!! Fix the issue most likely a bad connection.
ksg5000
Likely a defective GFI - when they go everything on that circuit shuts down. Check the GFI in the bathroom and kitchen area. Std GFI at any big box will be suitable replacement.
Kevin
Bobbo
A power cord with 2 male plugs on it is a Deadman Cord. When you plug in one end, the other end is hot and can electrocute you!
The one time I absolutely HAD to use a Deadman Cord, I used a regular extension cord, then made the Deadman Cord about 6" long. I could plug the Deadman Cord into the dead outlet first then into the extension cord. That way, the other end of the Deadman Cord was never hot AND exposed. When that need was rectified, I threw away the Deadman Cord I had made.
Bobbo and Lin
Dick_B
Maybe explain what is the Deadman Cord before the poster cuts off the wrong thing!
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
beemerphile1
ScottG wrote:
X2!
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
ScottG
X2!
Joe_Way
When this happened to my BIL's trailer it was a tripped GFCI for the refrigerator. Went to the outside access hatch and reset the GFCI.
downtheroad
Had that happen to me also...no power to a couple of outlets...
Discovered that the wires had been severed when they got tangled and then pinched by the slide mechanism.
Spliced the wires back together....then some electrical tape and shrink tubing.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
time2roll
newman_fulltime
if in a unit with a inverter go flip the breaker back on thats on the inverter itself
Fred_Sheri
It could be the outlets on inverred power, so isolation switch or battery
Dick_B
Any chance there is a second GFCI?
Dick_B
Equal-i-zer Hitch
