โDec-07-2013 08:33 AM
โDec-19-2013 06:11 PM
โDec-19-2013 05:18 PM
โDec-19-2013 08:52 AM
Fauxqui wrote:
...Should I keep them on the chargers all winter? Take them off periodically....
โDec-19-2013 06:23 AM
โDec-19-2013 03:19 AM
Heisenberg wrote:Well, that Big Boy has a rated output of 1.25 A. That right there should be the end of anyone's buying experience if you want to use it as a battery charger. As a maintainer, it might work well, so does a $5 wall wart.
westend, yes but the Big Boy does 9 Stages:
Qualification
Battery Rescue
Soft Start
Pulse Mode
Recondition
Bulk Charge
Absorption
Check Phase
Maintenance
Increased battery life for $29. A battery is actually a 6 cell device. The chemistry, lead acid, produces 2.2 volts per cell and 6 cells in series totals 13.2 volts on a fresh battery. A 12 volt wall power supply probably does not supply over 13.2 volts like your alternator or converter or battery charger. A lower voltage trains the battery to function there at that level, that is why we do not mix an old battery with a fresh one. The old one will pull life out of the new one. The Big Boy monitors voltage changes and adjusts to maintain the battery instead of setting there with a static voltage applied 24/7. Google the terms/stages. The big boy can be pulled off of the house batteries to charge your dinghy or boat or whatever and put back for maintenance. $29 is a bargain for this multitasker.
โDec-18-2013 09:29 PM
โDec-18-2013 06:36 PM
โDec-18-2013 06:06 PM
โDec-07-2013 08:53 PM
โDec-07-2013 08:40 PM
โDec-07-2013 05:44 PM
โDec-07-2013 11:01 AM
โDec-07-2013 08:41 AM
โDec-07-2013 08:38 AM
