Winter solar battery charging when you can't add water?
Buckshot_Bill
We have a solar panel on the roof of our travel trailer that keeps our two 6 volt batteries charged when we're boondocking.
This winter we're leaving the trailer in an RV park in the mountains at 6900 ft. elevation, and, as this is 180 miles from where we live, I can't add dist. water when the batteries need it.
The batteries will be un-attended for 7 months and temps will go down to zero or below.
I've been told to just dis-connect the neg. connection and not worry about the batteries, or
should I leave them connected with the solar charger running as usual
or
should I take them with us and hook a trickle charger to them?
Sorry to be so long winded about all this, but I'm really confused about which way to do this.
Thanks for any suggestions, BB
19 REPLIES 19
time2roll
3_tons
Removing the batteries and then replacing only once in seven months thus having no morning after sickness ($$)...Sorry, what was the silly question??
pianotuna
Nomad III
Nomad III
Hi,
The colder the better so long as they are fully charged. Mine winter nicely and we do get to -40. I do have solar.
Regards, Don
Buckshot_Bill
Thanks for all your different replies.
The rig in question will be in the White mountains of Eastern Arizona at 6900 ft. elevation- Show Low, Az. area- for those of you familiar with that "neck of the woods" (in an RV park and not out in the boonies,) so it'll be SOMEWHAT more secure, but I'm leaning toward the "put them in the back of the truck and take "em home" side too.
I'm mostly concerned about not being able to add H2O if they need it, and the variables about different loads, the cold killing them,etc.
Much obliged,I sure appreciate everyone's help.
Bill
JeepCB
Take them home. Better safe that sorry. You might want to take propane tanks too! Man if both were gone..................just sayin'
Good luck!
"Life is hard; it's harder when you're stupid" J.W.
2006 Dodge 3500 4x4 SRW QC/LB 5.9 CRD 6spd, w/Pacbrake.
2006 Denali 29rl-H5. 2 6V GC Batteries, but no solar yet.
mena661
smkettner wrote:
I would leave them on solar. No water should be needed for at least six months.
X2
RJsfishin
What make you think the batts will still be there when you get back ?
Too many risks, take them w/ you while you can.
Rich
MEXICOWANDERER
Diapered Horse Trots Up...
A lot depends on what the charge controller is capable of or more importantly what it isn't capable of.
Myself I like BFL's answer.
Spring arrives. You drive all the way up there -ooooooops ---- happens. The panel got covered with three feet of snow. Oops, something, a load turned on when it shouldn't have. Oops, the controller got a sudden case of PMS.
You find all this out not in your driveway but way the hell and gone back in the sticks. Where does it leave you. Up el creeko is where.
I like to weigh decisions like this using the "Risk Benefit" ratio. IMHO the teeter-totter with the take-them-home side is jammed to the ground.
landyacht318
If the solar controller has adjustable setpoints, lower ABSorptionVoltage to lower 14's and duration should be no more than 30 minutes.
lower float to manufacturer recommendations for expected temperatures.
Disconnect all loads on battery.
If batteries self discharge to 'zero' in winter, with all loads disconnected, then they are done for anyway and it does not matter what you do.
time2roll
Cold battery also has a much slower self discharge. Yes disconnect all loads if snow can linger for a few days or more.
TucsonJim
"As the state of charge in a battery decreases, the electrolyte becomes more like water and the freezing temperature increases. The freezing temperature of the electrolyte in a fully charged battery is -92F. At a 40% state of charge, electrolyte will freeze if the temperature reaches approximately 16F." I'd take them with me.
Source of information "Trojan Battery Company"
Trojan Battery Company Website
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
CA_Traveler
I conditionally agree. If the OP is referring to lower winter snow area (he lists Meza, AZ in his profile) then leave the batteries connected to solar.
Second condition is that ALL RV loads/wiring are fully disconnected from the batteries.
2014 Grand Cherokee Overland
Bob
BFL13
In theory you can arrange it right to leave them on solar and all will be well. OR for no nail- biting for seven months, you can take them home and know they are all right.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
westend
Leave on solar, set float voltage on controller, save your back for other tasks.
'03 F-250 4x4 CC
