Wire Size to Connect 2 12V Batteries?
cruz-in
Hi Team,
Was helping a friend clean their battery terminals and noticed her two 12 Volt batteries were paralleled with about 12 gauge wire. Seemed small to me. The coach power/ground wires are 6 gauge.
I would appreciate your input in
1) Is this a hazard?
2) What is the proper size wire for connecting two 12 volt batteries?
Thanks
Dan
2011 Monaco Vesta
Interesting Coach
This particular one was the prototype.
23 REPLIES 23
jrnymn7
If you also use only a 10a charger.
pianotuna
Nomad III
Nomad III
The maximum measured draw for my RV was 276 amps. Fused at 350.
Harvey51 wrote:
The maximimum current I can draw is about ten amps, with furnace and all the LED lights on. Twelve gauge wire would be adequate.
Regards, Don
time2roll
It is not just the load... what is the fuse rating?
Or does the #12 become the fuse?
Harvey51
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
beemerphile1
enblethen wrote:
I would get the ready-made battery cables. Most are #4 from your local auto parts store.
Same here, the pre-made cables are cheap and readily available.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
jrnymn7
I used cheapo store bought ends, originally, and within one season they were rusted. So I went from 4ga with cheapo ends, to 2ga with good quality ends, and reduced voltage drop by two thirds, at 45a.
2oldman
time2roll
I would use #6 or better. Nothing wrong with #4 battery cables from Walmart etc. with premade ends. Connect them balanced while reassembling them.
tenbear
Like others have said, I rewired my battery to converter, replacing the #8 wire with #4. I did this mainly to reduce the voltage drop in the 20' or so of wire when I changed to a smart converter.
2010 Subaru Impreza Sedan
toedtoes
We just rewired my house battery to engine battery/alternator connection - it was about 10-12 gauge. Used 4 gauge wire throughout. Since we were adding circuit breakers into the system, I went to Battery Bill and they cut the wires to size and added all the appropriate sized lugs to each end, and heat shrinked them with the appropriate red/black colors. Cost was only $1.85 per foot.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Sandia_Man
X3, pre-made battery cables from virtually every auto parts store, even Walmart carries a few varieties.
RWDIII
X2
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
