My thinking is 4AWG cable being so much available and does not coat all that much I use this gauge for all my two up to four battery wiring projects. All of my wiring uses the appropriate sized ring terminals. I always use equal lengths when wiring is used together for like connections.
I buy 25-foot spools of Marine Grade ANCOR cable purchased from EBAY STOREs for around $50 and cut my own DC cables. I also use a 8-ton hand crimper and adhesive heat shrink ends when using the ANCOR BRAND Ring Terminals. All of my 12VDC connection use the battery component stubs just about everywhere.
I also use BLUE SEA HD Switches, Terminals, Fuse Blocks, etc for all my 12VDC projects.
This allows me to make changes when needed and not have to do the wiring all over again...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
