โJun-23-2015 04:28 PM
โJun-28-2015 07:26 PM
โJun-28-2015 05:26 PM
tboss wrote:
a ball peen hammer,,a dull coal chisel and something hard to lay it on and line the chisel up with the center of the lug and wham jobs done wrap it in heat shrink and go camping ,,worked for me for years.
โJun-28-2015 12:32 PM
โJun-27-2015 08:00 PM
โJun-27-2015 07:04 PM
MEXICOWANDERER wrote:
Unh unh. A GREENLEE ratchet cutter costs 700 dollars. The image shows cutters that will slice 2/0 but dull after a hundred cuts. Need fairly strong hands. Let's see if I can find the ratchet cutter...
โJun-27-2015 06:54 PM
CA Traveler wrote:Naio wrote:Nope that's brass. The entire unit is a 500A precision shunt which is used with a battery monitor, in my case a Trimetric. The small wires provide the voltage sense capability for the Trimetric to measure battery drain/charge, etc.
CA Traveler, what am I looking at here? Are those blocks of WOOD, with layers of metal let into them? What's all that about? And what are the teeny wires in the housing? My eyes iz confused.
For 500A the shunt has a 50mV drop.
โJun-27-2015 06:39 PM
โJun-27-2015 06:30 PM
โJun-27-2015 06:17 PM
โJun-27-2015 06:05 PM
HF has a 10" length ratchet cutter that I have chopped 350 MCM wire with.
โJun-27-2015 05:56 PM
โJun-27-2015 05:28 PM
โJun-27-2015 05:22 PM
CA Traveler wrote:brulaz wrote:
Do people here use flattened 1/2" copper pipe for bus bars and battery interconnects too?
How much current can it carry? Too much to worry about?
3/4" pipe. If you are concerned about current capacity use the heavier wall pipe. Or calculate the area and look up the amp capacity.
And those are AGM batteries so not concerned about fumes for the shunt.
โJun-27-2015 05:04 PM
โJun-27-2015 04:44 PM
