โNov-11-2007 07:40 PM
I have per the request of a few members, stickied this post. Please note, this is not a place to argue whether a law makes sense or not, just what the laws are. If you have a question about wt laws, that appears to be NOT answered in some way shape or form, please ask, and hopefully some of the ACTUAL weights and measures LEO's will answer, or those with some actual knowledge.
In the mean time, I do thank the OP for starting this thread, altho I have taken the liberty to change the title to one I think and hope will be a bit more informative in name.
marty
TV moderator
โNov-24-2007 09:44 AM
BertP wrote:
But, you didn't address the first part of my post. I understand what the weight limits are, but none of my vehicles will ever see anywhere near 20K lb per axle. So, that restriction simply does not apply to me or to most people on this forum. The problem as I see it is figuring out the weight at which I can be ticketed. That weight will be much higher for my dually than my Venture, but neither will even approach the normal weight limits.
So, how do we define "overweight? Is it only when you exceed the 20K/axle, etc or is it the weight at which you can be ticketed? It has already been established that there are DOT weight limits for our tires so if I exceed the weight limit of my tires is my truck "overweight"? I know I can be ticketed, but I am not over the other weights. My truck doesn't have a registered weight, so I can't be over on that.
Bert
โNov-23-2007 04:06 AM
โNov-21-2007 12:43 PM
โNov-21-2007 10:59 AM
BertP wrote:
I'm not sure what you are trying to say here. Are you saying that the 20K/axle, 34K/tandem and 80K gross apply regardless of what I register my vehicle for? That would make sence to me.
โNov-21-2007 05:50 AM
Wadcutter wrote:
We've been thru this before Bert on another thread, and also in this one.
You are talking 2 separate laws and somehow are thinking one is related to the other. Registration weights have nothing at all to do with axle/gross weights.
Registration weight limits is a tax. It's the amount a person pays to haul a certain amount of weight. If your state/province doesn't register their small vehicles by weight then it's not an issue for you.
Wadcutter wrote:
Axle/gross weights apply doesn't matter what your registration says.
โNov-21-2007 04:34 AM
โNov-21-2007 04:18 AM
BertP wrote:
What about States and Provinces where there is no registerd weight for a vehicle? Here in Alberta, unless you register your truck as commercial, you cannot register any weight. So, my Chevy 3500 dually has no weight registered. Does that mean that as long as I don't exceed the 20K lb per axle or any bridge or road weight limitation that I cannot be fined for having an overweight vehicle?
โNov-20-2007 03:21 PM
โNov-20-2007 07:53 AM
Wadcutter wrote:
Once again you are confusing 2 separate issues.
I'm done discussing it with you. You have a mental block on separation of the 2 laws - overweights and registration. 2 separate sections and one not related to the other. It's impossible for me to explain it any clearer than I have. However, your mind is made up and you can't seem to separate the 2 issues. That's a clear indication of someone not fully understanding the topic.
โNov-19-2007 05:09 PM
โNov-19-2007 03:22 PM
JIMNLIN wrote:
let me say this again. When we apply and operate with combined plates for a 3500 truck [example] the door tag GVWR and the trailers GVWR is added together to make my combined numbers.
JIMNLIN wrote:
your interpetation of your state weight laws and what mcs laws your state enforces may hold true in your state but your mistaking other state interpetation of those laws.
JIMNLIN wrote:
MY state will enfore door tag weights and is cracking down on non commercial users such as 3500 trucks pulling heavy construction equipment.
grey`eagle wrote:
Given the excellent information posted above. It appears that we RV'ers can safely and logically come to the conclusion that we are not subject to the weight laws (in IL and AL) for our class as long as we remain under 26,000#s.
grey`eagle wrote:
For those that don't quite understand the references MCS law , read the link.
grey`eagle wrote:
Based on my testimony before juries and Grand Juries, I strongly believe that the inference and comparisons of vehicle mfg'ers limitation decals to mattress tags will not hold up.
grey`eagle wrote:
If I'm not sadly mistaken, the reference to paint color is not on the limitation decal, it's buried in the VIN number. At least it is on the GMC and Ford products.
โNov-19-2007 09:04 AM
Now enjoying mother earth at ground level and one mile per minute.
โNov-19-2007 05:15 AM
Wadcutter wrote:JIMNLIN wrote:
Indeed those door tag GAWR are very much part of DOT inspection points that we get hit with if we are out of compliance on under 26000 combined plates. And the shift captains comment that they use the same vehicle plates [registered GVWR and door tag GAWR] just as DOT uses for over 10000k vehicles and under 26000k weights.
That tag has nothing to do with legal weight limits. Where the 26K kicks in is for determining when certain MCS laws apply. Those tags are non-enforceable for determining overweights which is what the OP was asking about.
let me say this again. When we apply and operate with combined plates for a 3500 truck [example] the door tag GVWR and the trailers GVWR is added together to make my combined numbers. If the state the truck is registered in has a uprate GVWR [as my state] that it is my registered GVWR. My last 3500 DRW had the 15000 GVWR uprate registration plus the 16000 GVWR trailer gave me my combined 31000 lb combined. Other operators say some states don't have a uprate GVWR so they were required to use their truck plates GVWR for their registration. dot also checked my GAWR [RAWR/FAWR] per door tag for proper load distribution. Thats all per dot requirements and how dot enforces under 26000 lbs and over 10000 lbs.
We don't use the tags to determine MCS either. We use the registration weight limits. Once again, the door sticker which is more correctly referred to as the federal sticker is not required by MCS or any other statute after initial sales. It's like the mattress tag. There are vehicles all over the US legally operating without the fed sticker. If a vehicle has had damage repaired in the area of the sticker or the vehicle has been restored and repainted then they most likely no longer have the fed sticker.
Here's one way to better describe the fed sticker. On my fed stickerfor my Dodge pickup it not only lists the manufacturer's weight limits but it also lists the amount of air for the tires and vehicle colors. It says tire air pressure is 50 psi. If I want to put 65 psi in my tires there's not a thing illegal with that. That sticker also says my color is maroon. But I want to paint my truck blue. Nothing illegal with changing the colors even tho it will no longer match the fed sticker. That sticker is a listing by the manufacturer of the manufacturing specs for that specific vehicle.
Also, you are confusing weight laws and MCS laws and registration and axle/gross weights. All of those are completely different statutes, which I have tried to explain previously.
[snip]
However, there is definitely confusion here. You are confusing MCS laws and weight laws. Those are 2 separate distinct sections of the law, neither of which has anything to do with the other. Weight laws are not MCS and MCS are not weight. MCS laws do not apply to the guy pulling his RV south for the winter or to the mountains and his favorite fishing hole in the summer.
Please, don't confuse MCS issues here. They have absolutely no application.
โNov-19-2007 04:35 AM
grey`eagle wrote:
Also a specification of weaving in and out of traffic, or excessive lane changes (CA). OR "Failure to pass to left safely", this used in TX when a suspect rear ends another auto among other combined issues.
grey`eagle wrote:
I was advised by one of the LEO's that the point factor is higher should the person be cited and found guilty of the "careless and reckless" charge.
adamrmathis wrote:
And I happen think it is worth repeating:
LEO's are subect to the same errors the rest of us are. As a human, we all make mistakes. I'm not trying to bash any LEO's, just tring to point out that being a LEO doesn't make one correct.
โNov-18-2007 07:07 PM
