2008 inferno electrical issues
Wixi98
We have power all day until around 6pm. Then the power fades to battery power ,or surges up n down.
Campsite power is good had them check that first.
Anyone have this issue that may help us out as to where to start next?
6 REPLIES 6
ScottG
Sounds like either the converter, battery or both have failed. As Don said, you need to monitor the voltage when this occurs.
dedmiston
Moderator
Moderator
Welcome to the forum. I'm glad you found us.
Have you had any luck yet?
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
pianotuna
Nomad III
Nomad III
check the output on the converter when it is dark outside.
check the battery voltage when it is dark outside.
Regards, Don
CA_Traveler
QCMan wrote:
Sounds more like he is having an a/c switching issue as he states that the shore power is good. I cannot help on that one.
Llittle info and lots of possibilites. I agree but doubtful the pedestal power was checked at the time he has the problem. It's likely his problem but...
OP Recommend you buy a plug in 120V meter and check the voltage inside. You can buy an inexpensive VOM from Harbor Freigh but be aware that probing 120V AC can be dangerous should not be done without full awareness of safety procedures.
Thoughts - try a different site. What does "fades to battery mean"? Do you hear any relays clicking?
2014 Grand Cherokee Overland
Bob
QCMan
Nomad III
Nomad III
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
CA_Traveler
Not much to go on but as a WAG. You have solar power for the batteries and some 120V units need 12V for controls and don't work right when the solar power ends.
Start by checking AC voltage and DC voltage. Load check the batteries. Could also have low AC voltage in the evening.
Bob
