May-23-2015 10:37 PM
May-26-2015 01:32 PM
Moose10 wrote:
Have not experienced any problems with water intrusion in my '06 1150, but I am going to replace the front marker lights with LED's this summer and make sure everything is sealed well.
May-26-2015 09:58 AM
May-25-2015 09:17 AM
bobndot wrote:
My 04 had the exact same delamination issue.
May-25-2015 08:50 AM
May-24-2015 04:36 PM
May-24-2015 10:07 AM
May-24-2015 08:52 AM
jmtandem wrote:AF had issues with delamination early on. Sounds like water infiltration at one point and will only get worse if not addressed. Any seam or seal area is culprit. A good place to check for leaks is around the front cabover window seals. Another common area is the top roof seam where the cabover filon meets up with the roof. Once water gets into any of those areas it can run down into the under belly of the cabover.
Add to the above that often the clearance lights will leak. I would opt to keep looking as delam is the outward appearance of an inward bigger water intrusion issue.
May-24-2015 07:22 AM
May-24-2015 05:08 AM
