1/2 ton max tow shootout results
goducks10
http://news.pickuptrucks.com/2016/01/whats-the-best-light-duty-truck-for-towing-2016-texas-truck-sho...
Too bad GMC only puts the 6.2 in the high trim levels because it's definitely a winner for towing.
11 REPLIES 11
spoon059
I was never keen on GM products, but in 2009 I researched all the half tons before buying my Tundra. It was a HUGE turnoff not being able to get the big engine in a base model (or much lower trim level) in the GM products. Something I liked about the Tundra was that you could literally buy a stripped base model truck with the 5.7 engine. I ended up getting a few options on the Tundra, but not many. Loved that engine.
Now that I am in the Ram, I have a Tradesman (fairly stripped down truck) with the Cummins. I don't need fancy gadgets, I want a solid engine. GM will likely never get my vote for other reasons, but not offering a low trim truck with the big boy engine is disappointing...
2015 Ram CTD
2015 Jayco 29QBS
45Ricochet
That was my exact pick from last week. I'd still like to have seen the two new diesels offerings in the mix.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Bedlam
Moderator
Moderator
Disregard. Wrong thread.
carringb
lbrjet wrote:
The heavier GM's braked better than the Ford. That is interesting to me.
It's those low-rolling-resistance tires. Ford Transit has the same problem, the skinny tires make its braking distances quite a bit longer than the E-series vans it replaces.
2014 ORV really big trailer
2015 Ford Focus ST
lbrjet
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
TurnThePage
goducks10 wrote:
Only thing subjective is fit, finish, styling and comfort. Numbers don't lie. Hard to be subjective about 0-60 times, mpg towing and non towing, etc. While I'm not into 0-60 times, braking and handling are important. As well as empty mpg. These tests do offer information that's important to some. Pick and choose I guess.
Those numbers are somewhat important, but generally they were pretty close too. The lowest towing mileage was 10mpg. That's NOT bad for any gas engine. The GM twins got excellent unloaded fuel economy, and consistently scored at or near the top in the various tests, but otherwise didn't stomp the competition. There was no gap of even 2 seconds from first to last in any timed test.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
goducks10
Campfire_Time
BillyW wrote:
Truth be told they're all very nice rides now days.
And that is the reason I ignore these "tests". All very subjective when all is said and done.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
TurnThePage
That 6.2 is definitely a winner. Since they've started direct injecting the 5.3, it's no slouch either. Nice trucks! I gotta say though, I'm very happy with my Ram. Truth be told they're all very nice rides now days.
2015 Ram 1500
BB_TX
Not only do you have to pay for the premium trim, but then you gotta run premium gas thru it!
IdaD
The best half ton tow vehicle is like being the fastest kid at fat camp. :B
The results are about what I'd expect. Personally I'd buy an F150 if I were buying a half ton. I think it's bogus that you have to go to a high trim level to get the 6.2 in the GMs, and the 36 gallon tank is a great feature.
If I were a GM fan intent on buying a gas tow vehicle, I'd save some bucks and get a 6.0 in a 2500 - better tow vehicle for less $$.
2015 Cummins Ram 4wd CC/SB
