Jan-07-2018 05:25 PM
Jan-08-2018 07:02 AM
Jan-08-2018 06:45 AM
Charlie D. wrote:
There is an item called Speedi-sleeve....I have found that oil will weep between the O.D. of the seal and the ID. of the housing. Pematex should solve that problem.
Jan-08-2018 06:29 AM
Cummins12V98 wrote:
You may want to consider the QUALITY of seal you used! I have filled to the bottom of the hole on all 4 RAM's I have owned.
Jan-08-2018 06:01 AM
Jan-08-2018 05:52 AM
Jan-08-2018 04:45 AM
garyp4951 wrote:grey permatex on what? If you’re talking about the diff cover, yes I useRTV black to seal that. My problem is the oil seals on the outer wheel hubs. Or do you mean to use permatex on the metal outer surface of the seal where it presses into the hub? I haven’t torn into it yet so I don’t know exactly where it’s leaking but it do see oil slung on the insides of my rear wheels.
On a floating axle hub seal I use grey permatex, and no problems.
Jan-08-2018 04:16 AM
Jan-07-2018 07:24 PM
LIKE2BUILD wrote:ScottG wrote:
Are you following the diff fill procedure exactly or is it getting a bit too much fluid?
On some years the plug in the diff was a bit higher than the seals in the axles and filling her all the way up would cause the seals to weep slightly.
I bought the truck used and noticed the leaky seals at 110,000 miles. When I replaced them I filled to the bottom of the fill plug.
I don't have the exact fill procedure. Do you have a link to it? I'm finding references saying to fill with 4L of 75W90 and to be 1/4" below the fill hole with a +/- of 1/4". So basically that is saying you can fill between 1/2" below or right up to the hole.
If filling right up to the hole causes problems for the seals it seems odd the fill procedure would allow for it.
KJ
Jan-07-2018 06:07 PM
Jan-07-2018 05:28 PM
