19.5 and re-treads
Jon_L
With all this talk about 19.5 wheels I was just thinking.
I, like some of you went down the 19.5 road for the safety and the longevity of a commercial tire. They do last longer than a LT tire but not quite as long i would have hoped. I have steer tires on the front and traction tires on back. Rickson steel wheel and yes, it took about 5 months to get them 3 years ago. I have 60,000 miles on them now, the fronts are ok but the backs need to be replaced. We all know that there rated for retreading but are any of you doing that or just buying new tires. With 7,000 lb on the back axel i'm thinking new.
9 REPLIES 9
artguys
And for the regroove comments, beware. With the modern day tire anytime you cut/groove into the undertread your'e diminishing the integrity of the tire unless done by someone that completely understands the situation...and there are few out there that do, especially on this or any other internet forum.
artguys
60,000 on the rears is a very doable #...heck the same on the fronts would be great. Firstly there's not anyone poster on this site that I've encountered that has enough knowledge to comment on retreads, or as the industry now likes to be known as in the Remanufacture classification.
To with only buy retreads from the source manufacturer, not a 2nd or 3rd party. There are many that produce by the numbers not by the quality, most that is.
If you can't find a source check with the NTDRA(National Tire Dealers and Retreaders Association) for the nearest retreader.
If done right a retread should perform well enough to make the purchase worthwhile.
Reddog1
Times past (way past), I ran retreads. I have had retreads come off. Scary, but never lost any air. Today, I would not even consider retreads on my truck.
They say my tires are regroovable, but I do not think I am interested in that.
I had my Mitchlen 245/70R19.5 XDE M/S, mounted in Nov of 2006. My rear axle loaded is 6,200 pounds. I would have to review my records, but I think I have about 100,000 miles on them. If you only have 60,000 miles on yours, you might consider doing a little research for a longer millage tire.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Royals_Fan
I was driving a e-350 van about company van about 12 years back when a recap let go at 60 mph,the company no longer puts recaps on rigsโ€ฆ.trust me it was pretty much a E ticket ride!!
ISBRAM
We were using retreads on our medium duty fleet trucks on the drive axle with poor results, the retread company just couldnโ€™t seem to make a round and true tread. Because of this we were having vibration problems with those tires.
Now were only using brand new tires on the 19.5โ€™s same as on our light pickup trucks.
We still use retreads on the drive axels of our heavy duty trucks with 22.5 tires, for whatever reason they seem to be much better at making them round and true.
1999 Dodge Ram 2500 QC LB Cummins
2018 Airstream Flying Cloud 28RB
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
Jon_L
dadwolf2 wrote:
Just out of curiousity, what is the price difference? When big rigs use retreads on the rear, at least they have multiple tires supporting the load. I would go with new.
Retreads are about $180.00
Bedlam
Moderator
Moderator
Retread or Regroove? My tires can be regrooved when the they wear down. I would avoid retreads on a SRW. Even on a DRW, I would worry about body damage when the tread lets go.
dadwolf2
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
Buzzcut1
Nomad II
Nomad II
I see way too many retread (alligator Skins) carcasses on I580 to even contemplate it. One tread separation blow out is more than enough for me.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
