Today: Bathroom finishes, Bedding Introduction, Wheel Well Storage Access.
If you're paying any attention at all to the chapter names and categories, you'll find today we are in Chapter 7. Finishes and Finishing.
Right at the very beginning, I defined this chapter as a place to provide explanation for the various finishes we've chosen - whether a paint color, or a material used, such as the glass tile stove surround. But I also said, it would be at the end of this chapter where I would report on various odds and ends of the build, as we finished them.
That's where we're at now.
-Bathroom-
I already reported the bathroom build in its own chapter, and theoretically - that's done. There are some finishing touches to do in the bathroom, so I may report on them there, or in here, but at least for today, here's a bit of explanation for the finishes we used there...
The bathroom walls began with sturdy wood structural build, then on the camper back wall, some framing for a 3/4" cavity of foam board insulation, but over all that, we used that home-center, very thin and flexible, plastic 4 by 8 sheets of surfacing stuff.
Plas-TexFor corner sealing, we used acrylic (no silicon added) white exterior home caulking. Additional metal finishes are everything from Brass and Chrome fixtures to Aluminum banding to Zinc plated fasteners.
We're still considering the possibility of Gold-plating the Porti-Potti toilet seat (as a modification) - if our tax refund is big enough - I hear it's coming from China in the form of "free money". Yeah! I wanna get me some of that "Chump Change".
-Bedding-
Now this could go in the "Night-Chamber" chapter, but we'll just put it here. This is a bedding introduction.
It's hard enough to climb up in a cab-over bunk. It's another thing to try and "make a bed" up there. You use one hand to lift the mattress corner, another hand to brace yourself, and your third hand to tuck the bedding around the mattress. They called me old "tripod arms" in my younger years, but lately I've been having some bursitis in my middle shoulder.
So DW's solution is to modify some sheets, and make quilts or blankets that require much less tucking, and provide for much more fastening in new and improved ways. She envisions some "buttoning" methods to hold top bedding to the lower foot areas. We'll report on this as she works it.
The odd sized mattress (in essence, a "long-boy double" - meaning the bed is king or queen length, and a double or "full" width, and only 5 inches deep), requires homemade modifications. Which she is doing with some flannel sheets and stuff. The camper mattress now resides on the guest bedroom bed - making it a "work area" across the hall from DW's sewing room.
See DW is a quilt maker. No - not one of these "I'll enter a program into my machine" quilters. Rather, she pieces. And she has done some beautiful work! Check out this quilt she made my Mother 10 years ago, which Mom proudly uses for half the year in her assisted living home apartment
The objects are all "pieced fabric".
"Grandma's Garden" (referring to mom's children and grandchildren and greats, etc.) That's a picket fence (mom's childhood home) and the Utah beehive (Mom is a Utah Mormon). Not sure if you can see close enough, but there's even a bunch of tiny bees DW cut out (the size of a dime), attached and then fashioned a bee's flight path behind each in loops and circles with a threaded stitch! DW is amazing in many ways, not the least of which is her fabric creativity.
I could make several posts just about her creations. But guess what! She's making a special Lil' Queeny quilt.
๐Here are some pictures of the early stages.
So stay tuned!
-Wheel Well Storage-
Now I don't know if we ever said this before, but Lil' Queeny is tiny. A tiny home even-en. And storage is always at a premium in a tiny home. It makes you look at those un-accessed wheel wells with longing. So I got me this idea, see?
There's already a small access door to the left, front access, which could also access the left side area above the wheel well. (The rear of the wheel wells on both sides are already pretty full with "camper".
But there's a huge area of wheel well storage on the right side, both above and in front of the well. And EVEN some space BEHIND the well, if you can access it. Which we couldn't. At least not from an access door on the camper box, like you will most often find.
Enter - the wing under the dinette cushion. Not the EASIEST area to access, but once accessed, it is HUGE! The only thing in the way is the "metal under-grid jack and tie-down assembly", (I don't know what else to call it).
I measured around it, and factored in the truck dimensions and stuff, and carefully penciled a template on the wing top surface. Then I used a scratch awl to mark the rectangles more visibly, while rounding the corners with a small round something-or-other.
I didn't get a picture.
Then, because I was re-using the removed board as the door, I jabbed my oscillating tool into the cut line (instead of my normal method of drilling a hole to drop a saber-saw blade into). Here it is under way.
And then cut out - before cleanup.
Then I made cleats out of 1x2's (3/4" by 1.5") to line the openings from underneath. I screwed from above and thru the 1/2" plywood down into the 3/4" thickness of the cleats. Four shorts, and four longs. Primed and then painted the OD green found elsewhere on Lil' Queeny's under-areas.
Note the board edges, and the cleats, done.
Also note the door handles. Flat, soft, made from one of my old belts. Also, non-grabby screw heads - so the carpeted cushion bases don't snag.
Same edge treatment on the openings. Note the screws backed out in certain locations, the result of designing while building.
Now with all the screws and cleats in place.
From underneath. I think this looks "factory original" don't you?
Now tell me this doesn't look "gypsy wagon-like"!
Our target was a sort of combo between "that cabin in the woods - but on wheels", and a little "gypsy-wagon" - goes by the name 'o Queeny.
I'll buy some thin, stick-on foam weather stripping for the edge seal (dust and drafts). All I have on the shelf is 1/2", and that's just too thick.
Now when you pull into the store parking lot to "re-stock supplies" (beer, water jugs, canned goods, etc.) or for storing bulky stuff like fishing rod tubes, tackle boxes, etc., you can remove the table and the center cushion, then semi-access by slightly lifting the other cushion edges to remove the door panels. Slick!
And with the cushions back in place, you'd never know.
๐Adding access to THAT much storage, in a unit like this, is greatly liberating! We envision large thick "yard-waste" bags with cinch ties. That'll keep things mostly dry and dust free, when needed.
