2000 silverado front end binding
Thunderbolt
I am still working on this POS. I replaced a bad front differential in this Chevy 1500 because it was banging and grinding. I put a used one in and it was making noise and binding even in snow. They gave me another one and it is no different. The bind is so bad that from a dead stop with any turning of the wheel it feels like something is going to break. If I let of the gas while going slow with the wheel turned the truck will stop as if the brakes are on. If i shift to 2 hi without touching the gas it will immediately start rolling. This isn't the normal bind of a 4wd, it is severe. The salvage yard insists it is the correct gear ratio, but I am wondering, although the odds of them being wrong twice isn't likely. Any ideas ?
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM 293,000 miles
98 K1500 4x4 heavy duty 1/2 ton (Sold)
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
380,000 miles.
39 REPLIES 39
Thunderbolt
Canadianxplorer wrote:
Hey guys,
Not to ignore the obvious, what about the tires? Are they all the same level of wear and brand? I know the OP said it was ok while driving straight but sometimes tires that are badly worn vs newer can cause some strange stuff.
I was wondering the same thing. I am going to measure the circumference of the tires.
Bryan
380,000 miles.
Thunderbolt
I know what you are saying, but it does not bind in 2wd. I too am thinking it has to be in the transfer case. I never that of seeing if it moved in 2wd without the rear drive shaft. Everything locks up electrically, but all appears to be working.
Bryan
380,000 miles.
enblethen
Me Again:
That is why I have been asking how the front end is locked up.
Here is something that popped into my head. The encoder that operates the transfer case could have jumped a function.
encoder
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Me_Again
Thunderbolt wrote:
So I pulled the rear drive shaft today and drove with just the front differential and had no binding and less noise. I then pulled the rear differential cover and everything looked good. Nothing in the fluid, gears wearing good and everything intact on the G80. Refilled the differential, put the drive shaft back in and it still binds. I am starting to think it has to be the transfer case. I am throwing in the towel and it is going in to a shop.
Well you missed one test while you had the rear drive line out!!! You should have put it in 2 wheel drive and checked to see if it moved. Sounds like it is always in 4 wheel drive!!!!!!!!!!!
Transfer case issue! Is this a manual shift transfer case or an electric one. Chris
Canadianxplorer
Hey guys,
Thunderbolt
Bryan
380,000 miles.
Ozlander
On my Yukon XL, the back diffy is a locker and the front is a limited slip.
I think the limited slip is supposed to have an additive in the lube.
Sounds like it's not slipping.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
dodge_guy
Have you checked to verify the ratio in the rear axle?
Never mind! I forgot you said it doesn't do it going straight!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
enblethen
How is the front end engaged? is it electrically operated or ??.
It must have some mechanism other then centrifugal? My big Suzuki use a small vacuum line that connects to front differential.
What happens when you lift the front end off the ground and spin tires by hand?
Bud
USAF Retired
Pace Arrow
Thunderbolt
enblethen wrote:
Have you looked at the axle universals and CV joints?
U-joints are new. CV joints seem ok and make no noise.
Bryan
380,000 miles.
enblethen
Bud
USAF Retired
Pace Arrow
Thunderbolt
enblethen wrote:
And along with "All I could afford', it is not in the transfer case.
Still sounds like in the front axle assembly.
Does it matter which direction you turn?
Turning does not matter. I am stumped. I thought maybe carrier bearing and the carrier is binding under a load, but I would think it would make noise in 2wd since the carrier is turning even in 2wd with auto-trak trucks. We are going to pay someone to look at it. I am tired of it and I honestly am lost. I can usually figure things out, but I must admit defeat on this one.
Bryan
380,000 miles.
enblethen
Bud
USAF Retired
Pace Arrow
All_I_could_aff
If it doesn't bind going straight in 4WD on dry pavement, you can safely assume the two axles have the same ratio
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
