2010 Coachman 24RKS electrical problems
predrag_5
Hey all! new to the forum and looking for a bit of help. Lost power in the entire back end of my unit. First noticed when my outside receptacle lost power. I checked all the fuses and reset all circuit breakers. not sure where to look next.
thanks in advance.
7 REPLIES 7
predrag_5
Thanks to all who responded. I have checked and double checked everything but still can't find the source of the problem. I will make do with the electrical I have left until I get home where I get a professional to look at it.
Chuck_thehammer
my Coachmen trips its GFI often.. there are 2 in my trailer.. and 6 to 8 outlets are connected downstream of them each.
the other day. we had a town wide power outage.. 20 minutes.. but when I went to check on the trailer.. both GFI's had tripped also.
No AC to anything except power converter for the trailer battery.
mine is a 2005 Coachmen Cascade 29FKCS
happycamper002
If you lost power to outlets located outside, and some outlets in the kitchen, chances are a GFCI is tripped. Checked the outlets in the back end of your RV and look for an outlet that is GFCI (GFI). Some outlets are daisy-chained via this GFI outlet.
_1nobby
I lowered all the coroplast under my trailer just for a look see.
Good thing, too. Mouse nest and wires chewed through.
1492
Moderator
Moderator
Moved from Forum Technical Support
jhlady
Check and re-set any GFCI outlets. Kitchen,bathroom,outside outlets etc.
Mandalay_Parr
See if you can find an electrical person to help you.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
