โAug-31-2014 05:17 PM
โSep-04-2014 05:09 AM
โSep-03-2014 06:22 AM
missionman wrote:Mvander wrote:waltah wrote:Mvander wrote:
The 5.0 has the same HP as the eco(minus 5) but you will have to access it differently.
quite the gap in torque across the entire rpm range. the engines arent comparable, they were built for different purposes. The 6.2 is more comparable to the EB than the 5.0
Lot of threads about HP VS. Torque. If you stomped on both of them with a similar load the results wouldn't be much different at the top of the hill. The eco would run generally lower rpm though.
There can be lots of threads about anything, I have owned both trucks with each of the drive trains that are in discussion.
Riddle me this, on the same 7% grade highway under the same load and weight. Why does my EB hold 65mph in cruise control and my 5.0 downshifted multiple gears and slowed to 40mph for the entire climb? Your argument is as ridiculous as the guy saying his 5.0 doesn't downshift on hills in 40mph winds. I don't live in indiana, I travel and camp the Adirondack, finger lake, white mountain, and Appalachian regions.
I've owned both, I've hauled heavy loads in the bed with both, I've towed heavy with both, I've towed the same highways with both.
Have you?
โSep-03-2014 06:20 AM
I call BS. You don't know what my truck does when I tow. You obviously have something wrong with yours as I pointed out, and used that as an excuse to buy a new truck. Pickuptrucks.com blah blah blah
โSep-03-2014 06:08 AM
โSep-03-2014 05:58 AM
โSep-02-2014 07:35 AM
โSep-02-2014 07:11 AM
โSep-02-2014 04:53 AM
waltah wrote:Mike Up wrote:
Since it looks like you'll be really close, you may want to find a 3/4 ton truck that has more payload for your heavier travel trailer.
Good luck.
Or he could find a max tow and/or hd payload with 7700 or 8200 GVWR. Would be more comfortable towing a 33ft with a 3/4 though, I agree.
โSep-02-2014 04:48 AM
โSep-02-2014 03:36 AM
Good luck.
โSep-02-2014 03:34 AM
Mike Up wrote:
Sounds like you had bad fuel, clogged air filter, dirty fuel injectors or defective wire by throttle accelerator. ๐
Drove in 40 mph winds and very large hills with demanding grades, always had reserve power and never needed to have 4K rpms to maintain speed. Trailer is a 6500 lbs loaded tall Jay Flight 29' length 26BH.
Never a problem controlling the trailer going down hills or even in wind with my Reese Strait-Line hitch. Truck has plenty of engine braking and torque down low. Has more torque down low than my previous, nearly identically configured 2010 Screw 4WD 5.4L w/3.55 LS truck. Same transmission gearing but slightly lower ratio axle gearing that would had supposedly equaled the torque between the 2. BUT the 5.0L still had gobs more torque down low, than the 5.4L, despite that.
Perhaps you're just use to driving 3/4 - 1 ton diesels that rarely rev past 3000 rpms and make their torque peak at a barely moving 1500 rpms.
I've towed with numerous 1/2 tons and midsize trucks and this F150 5.0L is the best by far, out of any of them.
โSep-01-2014 10:03 PM
baitboy wrote:
Sorry about the lack of info. Here are the facts. 2011 F150, SuperCrew Cab, 4WD, 7200# GVWR package, 36 gallon gas tank, Trailer tow package, 5.5' bed, the truck will have myself, my wife, 40 lbs of dog, 200 lbs of stuff in it, P275/65R18 tires, Trailer brake controller, off road Package, select shift Transmission and the truck has a Soft tonneau cover. I hope this helps and I really appreciate your help.
โSep-01-2014 12:24 PM
โSep-01-2014 12:18 PM
โSep-01-2014 11:49 AM
missionman wrote:
I towed my #6500 TT with a 2011 3.55 5.0 4x4 SCAB F150 regular tow pckg. note* I bought the truck before the TT not knowing the true dynamics of tow capacity and payload. 5.0 payload isn't good without the max payload option. I was within 100-200#'s of my GVWR with passengers/cargo/TT tongue weight.
Upgraded the truck after driving in the Adirondack/finger lake region. Need over 4k rpms to get to the meat of the torque to get up long grade changes and even had to romp on it to get up to highway speed. Once you were cruising it was okay, it would gear hunt even with 6th locked out but expected with high revving V8. You knew the trailer was in tow with the 5.0, or even hauling a load (pavers, topsoil, etc.) It got the job done though. Couple that with the 147" wheelbase and I was ready to upgrade.
The 5.0 drivetrain will get the job done but doesn't really feel comfortable towing/hauling at its towing/payload limits, YMMV.
