From the Jayco Towable Limited Warranty:
"WHAT IS NOT COVERED
By way of example only, this limited warranty does not cover any of the
following: defects in materials, components or parts of the RV not attributable to
Jayco; items that are added or changed after the RV leaves the possession of
Jayco; additional equipment or accessories installed at any dealership, or other
place of business, or by any other party, other than Jayco; any RV used for rental
or other commercial purposes (Note: It shall be concluded that the RV has been
used for commercial and/or business purposes if the RV owner or user files a tax
form claiming any business or commercial tax benefit related to the RV, or if the
RV is purchased, registered or titled in a business name); any RV sold or used
JAYCO TOWABLE SECTION 1 โ WARRANTY & SERVICE
1-10 TT/FW
outside the United States, U.S. Territories or Canada; any RV not used solely for
recreational travel and camping; any RV purchased through auction or wholesale;
any RV purchased from a dealer that is not an authorized dealer of Jayco; normal
wear, tear or usage, such as tears, punctures, soiling, mildew, fading, or
discoloration of exterior plastic or fiberglass, or soft goods, such as upholstery,
drapes, carpet, vinyl, screens, cushions, mattresses and fabrics; the effects of
condensation or moisture from condensation inside the RV or failure to provide
adequate ventilation; mold or any damage caused by mold to the inside or outside
of the RV; imperfections that do not affect the suitability of the RV for its intended
purpose of recreational use or items that are working as designed but that you are
unhappy with; problems, including water leaks, related to misuse, mishandling,
neglect or abuse, including failure to maintain the RV in accordance with the
ownerโs manual, or other routine maintenance such as inspections, lubricating,
adjustments, tightening of screws and fittings, tightening of lug nuts, sealing,
rotating tires; damage due to accident, whether or not foreseeable, including
any acts of weather or damage or corrosion due to the environment, theft,
vandalism, fire, or other intervening acts not attributable to Jayco; service items
such as windshield wiper blades, lubricants, fluids, filters, etc.; damage resulting
from tire wear or tire failure; defacing, scratches, dents, chips on any surface or
fabric of the RV; damage caused by off road use, overloading the RV or alteration
of the RV, or any of its components or parts; wheel alignment or adjustments to
axles when caused by improper maintenance, loading or damage from road
hazards, including off road travel, wheel damage or balancing or damage from tire
failures. Also, any costs associated with obtaining service, including by way of
example, travel costs, are specifically excluded from the coverage of this warranty."
