โFeb-23-2014 06:57 PM
โFeb-25-2014 07:46 AM
APT wrote:
Towing a TT within all the TV's ratings using a quality WDH with integrated sway control will be just as comfortable as a 5th wheel RV. Do not chose a 5er or TT because of how you think it will tow.
There are compromises for each type. Use of truck bed, number of RV entry steps, RV floorplans, weights, interior height, etc. Prioritize those aspects for your situation, not mine or anyone else.
For the same length RV, a TT will weigh and cost less. A TT is lower entry and usually has lower interior height. 5er usually has more outside storage and generally easier to hitch/unhitch.
My opinion is that you get a lot more RV for your money in a TT for half and 3/4 ton pulling. If you can tow about 6k loaded 5er, then you get closer to 8k in a TT because the hitch hardware weighs less.
โFeb-25-2014 05:58 AM
โFeb-24-2014 11:00 PM
โFeb-24-2014 08:14 PM
APT wrote:
Almost 1600 pounds is better than I expected. So you'll have maybe 800 pounds of pin weight, 250 pound receiver, leaving 500+ pounds for people and a little cargo. Looks good to me!
Just curious, why does that small/light 5er appeal over a similar size/weight TT?
โFeb-24-2014 06:31 PM
โFeb-24-2014 04:54 PM
camp-n-family wrote:
Alright, subtract the weight of all the passengers and stuff you plan on carrying in the truck from 1592lbs (average for a 1/2 ton truck). Subtract another ~200lbs for the weight of the hitch in the bed as well. What you have left is what you can have for the fifth wheels pin weight. If pin weight is under that remaining weight then you are good to go. Keep an eye on your rear axle weight rating too. Being a little over payload isn't that big of a deal as long as you're under the RAWR. That's a little harder to determine without going to the scales.
You will be able to tow a much larger trailer than 5th wheel though. With a fiver the truck needs to carry the pin weight which is 20-25% of the trailers weight. With a tow behind trailer you have the tongue weight but it is much lower, usually only 10-15% of the trailer weight.
โFeb-24-2014 04:10 PM
โFeb-24-2014 04:01 PM
usmohls2@yahoo.com wrote:joelyn wrote:
have a 2012 ram 1500 2wd crew cab and found a small 5th wheel 21 ft with a dry weight of 4040lbs and a GVWR of 5756 LBS. should my 1/2 ton ram be able to handle this?
thanks
Does your truck have a tow package? Heavy duty radiator, transmission cooler, wiring harness?
โFeb-24-2014 03:58 PM
APT wrote:
Locate this sticker. Note what yours has where mine says 2051:
โFeb-24-2014 02:39 PM
โFeb-24-2014 02:30 PM
thanks
โFeb-24-2014 02:22 PM
โFeb-24-2014 01:09 PM
โFeb-24-2014 12:37 PM
