โMar-24-2019 02:19 PM
โApr-02-2019 05:20 PM
โApr-01-2019 12:43 PM
โApr-01-2019 10:39 AM
โApr-01-2019 06:47 AM
โMar-31-2019 08:29 AM
โMar-26-2019 10:02 AM
Grit dog wrote:
Sweet! Good times ahead!
Iโll be on the lookout for a 450 with a NL this summer!
โMar-26-2019 09:40 AM
โMar-26-2019 07:55 AM
โMar-25-2019 09:57 PM
โMar-25-2019 07:59 PM
S and S Peaches wrote:
The 2016 F-450 has a factory seven pin in the rear of the drivers side bed that I was planning to plug in the new camper. I though I could easily make up or purchase a ready made extension if the camper plug-in cord is too short.
โMar-25-2019 09:58 AM
KD4UPL wrote:S and S Peaches wrote:mbloof wrote:
Get a 7pin RV outlet installed in the front drivers side of the bed.
Enjoy.
- Mark0.
Thanks Mark, couldn't I just make up an 7-pin extension if needed to plug into the 7 pin in the drivers side rear?
If you're going to pull a trailer you will need the rear connection for the trailer lights. Or, you would need a Y adapter to plug both the camper and trailer into that rear connection. I would much prefer installing a 2nd plug up front for the camper.
โMar-25-2019 09:49 AM
โMar-24-2019 07:14 PM
Enjoy.
- Mark0.
โMar-24-2019 05:07 PM
I have a 2016 F-450 crew cab that were going to use to carry a 2019 Northern lite 10-2 with. Is there anyone else with a similar truck and camper set up that might advise some prior truck prep before picking up our camper last of April first of May? Our camper is being built in April.
I'm adding Stableloads, and a SuperHitch Magnum with a 36" extension. I plan on pulling either a two horse trailer or a 16 ft. Fiberglass Trihull boat. I'm wondering if anyone with my setup had any clearance issues between truck cab and camper. Should I consider a bed mat addition to lift the camper up a little? All advice considered.
Thanks in advance.
