Jan-22-2017 05:23 AM
Jan-23-2017 08:46 AM
Jan-23-2017 08:03 AM
Jan-23-2017 06:57 AM
Troutguy wrote:
I respectfully disagree with this statement. According to the 2016 RAM 2500/3500 brochure "The 5.7 HEMI V8 and the 6.4 liter HEMI V8 are mated to the long-proven 66RFE 6-speed automatic ". I don't believe that the AISIN trans is available with the gas engines in the 2500/3500 trucks but that combo may be available on the 4500/5500 gas engined trucks.
I believe that the OP is referring to test driving the 3500 series dually.
Jan-23-2017 05:35 AM
Jan-23-2017 04:43 AM
KD4UPL wrote:
But, if I were picking a new HD truck with a gas engine I think the RAM 6.4 would be the one to get. Particularly since you can get that engine with the Aisin transmission which adds PTO capability along with MD toughness.
RAM 3500 Crew Cab 4x4 DRW
Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWRHonda EU2000
Jan-22-2017 07:13 PM
jmtandem wrote:I am looking at this Ram at $32,000 out the door.
If you want to get some good baseline prices on the truck you want check the websites for Dennis Dillion and Dave Smith. Then you can go to your local dealer and negotiate.
Jan-22-2017 05:45 PM
Jan-22-2017 05:38 PM
Jan-22-2017 05:06 PM
Jan-22-2017 04:41 PM
Jan-22-2017 01:35 PM
Jan-22-2017 12:41 PM
Ram 6.4 with camper Review TC Magazine
Jan-22-2017 12:38 PM
towpro wrote:
wagonqueen,
you can go to the RAM body builders website pick your year and truck (17 is probably very close to 16 weights) than on left side you will see "camper guide" click on that. go down until you find your truck listed. (be sure to pick 3500, 2 or 4wd, match cab, bed length, engine, GVWR and seats. no field for SRW or dually, but that is already in GVWR field as SRW is less) I noticed they had a mistake and showed both 6.4 and 6.7 as diesel (3500's are 1/2 way down).
once you find your truck it will show you center of gravity info for truck campers. as well as "remaining cargo"
back on the main index screen, you can also click on the page that shows Base Weights/GCW/Payload/Trailer Tow
Jan-22-2017 12:09 PM
Jan-22-2017 11:48 AM
