2020 F350 6.7 weak start
way2roll
Navigator II
Navigator II
I bought my 2020 F350 6.7 new and I've put about 28k on it. I haven't had a single issue with this truck until now. Sometimes the truck sits for a day or so without being used and when that happens it's a "weak" start. It always starts (knock on wood) but the last thing I want is to be on a trip pulling the FW and it doesn't start. There is no code. It has 2 batts and frankly I don't know how to test voltage on a 2 battery setup and voltage isn't always the best indicator anyway. And I do know, if one batt is bad it drags down the other. I've also read that these trucks have had issues with the starters. It's still under warranty and I was told to make an appointment for a diagnostic test. But I trust you guys more than I trust a dealership and thought I'd throw it out there to get your thoughts so they don't brush me off. Also been noticing intermittent hard shifts into 3rd on a slight grade. Again no code, but I have heard there have been issues with these tranny's and intermittent hard shifting. I plan on asking them about it, but again, always worry about an honest opinion from the dealership. They always seem to find stuff when the warranty is over, but funny how they can't find the issues when it's covered.
Jeff - 2023 FR Sunseeker 2400B MBS
47 REPLIES 47
way2roll
Navigator II
Navigator II
schlep1967 wrote:
There is a new battery purchase in your near future. Probably one of the batteries is bad but you can't just replace one.
Agreed. One thing I do know is that all batteries should be replaced at the same time. I'll let you guys know what Ford says.
On Edit, got an appt for Monday. They want me to drop it off Sat so it sits for a few days to try and replicate the problem. She seemed familiar with the issue as well as with the hard shifting into 3rd. Hopefully they are both easy fixes. Didn't think to ask if I am paying for this diagnostic test. Been over a decade since I've had a new vehicle.
schlep1967
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
way2roll
Navigator II
Navigator II
Grit dog wrote:
So it cranks slower after sitting for only a day, but cranks faster if started within the same day as it was run last?
If that's the case, it is not the starter, it is the batteries.
If you dont want to test them, and suspect bad battery/power draw, just let it sit for a few days and see if it's worse than 1 day. Otherwise, check battery voltage of each battery separately and/or have them load tested.
That's where I'd start (no pun intended, lol)
Ha!, I love a good pun.
This pretty much explains the problem. It's a weak start after sitting a few days, but started on the same day or after being driven it starts right up. I guess that does sound like a battery problem. Just interesting that the batts would go bad in 2 years?
Busdriver
Power strokes are hard on battery life
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
way2roll
Navigator II
Navigator II
Appreciate all the replies. I'll make the appointment at the dealership and let you know what they find out.
blofgren
It could very well be the batteries getting weak, although Motorcraft batteries are known to be very good.
My Ram was beginning to crank slower at around year 3 as well, and I was having all sorts of weird glitches with the stereo and instrument panel. Then one day it wouldn't start. I installed 2 new fresh Kirkland batteries and all has been fine since. Erratic voltage from batteries starting to go south wreaks havoc on newer vehicles.
Please keep us posted!
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Retired_JSO
Cold weather start on 6.7 will take a second or two before the starter engages to allow the glow plugs to cycle.
jdc1
More and more **** is added to vehicles that have a memory, drawing power while you sleep.
dieseltruckdriv
Fisherman wrote:
thomasmnile wrote:
We have a 2019 Highlander. Was sitting in a parking lot waiting on my wife while she was in a fabric store. Ignition in accessory position, radio on nothing else. The master alarm suddenly goes off and the dash display pops the following message " shutting Ignition off to conserve battery". Radio only????? After 20 minutes????
Mfgr's put the smallest battery in there, thank the bean counters.
Actually not always. My wifes Taurus takes the same battery as my 7.3l Powerstroke. Only one of them though. ๐Ÿ˜‰
My best friend has a 2017 or 18 6.7l and he left his sit most of the winter without starting it and it cranked right up when he tried it early this spring.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
RAS43
Couple of issues and under warranty, time to trust the dealership, IMO.
Fisherman
thomasmnile
Have both batteries load tested?
Parasitic draw? What vehicle built these days doesn't have them? So many computers and stuff in vehicles now....
Good thing I can stream Sirius XM on my phone. Geeez.......
Bob_Olallawa
I think you should make the appointment to get it checked out. Maybe they will find the problem and take care of it.
Welcome to my home, that door you just broke down was there for your protection not mine.
theoldwizard1
So you have an intermittent "crank, no start".
โ€ข Check the battery voltage at both batteries. It should be identical.
โ€ข Does it crank a "full speed" or is it cranking slower ?
โ€ข The time that it did not start, what did you do to make it start ?
way2roll
Navigator II
Navigator II
My local auto parts store is literally a mile up the street. I'm certain they are better at doing a batt test than me. Does it make sense for them to check the batts before making an appt at the dealer and possibly leaving it there?
