cavie wrote:
Lots of $$$$$. You need new Electric panel, shore power cord, added circuit breakers, Transfer switch if you have a gen, an Electrician.
Money yes but it shouldn't be that bad.
Everything is still running 120v.
Swap out the panel and connect the breakers to one leg or the other. Assuming you aren't adding a 2nd air/con unit, I would put the air/con on one leg and everything else on the other. If the panel uses the same type, you could use your old breakers (assuming they are in good shape but they aren't that expensive). Maybe $150 for a new panel.
Yes, you need a new cord and inlet plug. Say $50 for the inlet and $200 for two 25ft cords.
Most 30amp RVs don't have a generator built in.
So about $400...round up to $500 for misc hardware, caulk, etc...
If you are comfortable wiring outlets in your home, this is within the DIY range of projects.
If you aren't comfortable with AC power, I'm thinking an electrician for 2-3hrs...and total cost should still be under $1000.
If you have access to 50amp pedestals most of the time, it would be a nice upgrade as you don't have to pay attention when running the microwave or you could leave the water heater on electric while the air/con is running.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
