6 pin connector wiring
aellarby
Hi, I hope someone can help me. I just bought a used Jeep and it came with a CURT pin socket where it will connect a cable from the RV to operate the lights on the jeep. I am confused by the various options, especially for the center pin. Some online drawings show the center pin for e-brake, some for auxiliary, some for 12 V power. The case is aluminum it is probably 8 or 9 years old. There are no other marking I can see.
I am attaching a picture.
Many thanks,
Andy
https://www.flickr.com/photos/aellarby/22795571137/in/dateposted-public/
4 REPLIES 4
Old-Biscuit
George H wrote:
There are 2 common ways to wire 6 pin connections, as noted in OP. The center pin can be either brake or charge/hot wire. If Jeep is to be a toad, you may not need either option.
YEP......
Black wire (12V +) or Blue wire (Brake controller) can be on center pin or top left (11 o'clock) when looking at receptacle on tow vehicle
The other wires are standard
Just need to use a meter and check which is 12V +
Center pin OR 11 O'clock
George_H
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
RoyB
Also confer with ETRAILER.com They are everything trailer with components, parts, and drawings. Also alot of how to videos...
Once you come up with the various part numbers then search AMAZON before you purchase - may be cheaper and faster to get the same items...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
agesilaus
Well it looks like this one:
Link
And this is their pinout
Hopkins
You can check some of the connections by using a multimeter in resistance mode. Check the ground plug against the vehicle frame for example.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
