7 pin trailer connector - no 12 volt for charging
ugh
I took a tester and tested the 7 pin trailer connecter. All pins worked except for number 4 12 volt charger. Is there something wrong or do I need to do something to turn it on to test it? Like put it in gear or what? The truck was running in parked when I tested it.
2001 F250 5.4 RWD
2001 F250 5.4 3.73
2015 Wildwood X-Lite 262BHXL
15 REPLIES 15
ugh
Bought the fuses and installed it. It is working now. Strange that it takes 2 relays and 2 fuses to get it to work. But, I like the idea that it only supply 12 volt when the key is turned on and not all the time.
Thank you for your help.
2001 F250 5.4 3.73
ianmac23
My GMC the dealer told me it was a dealer installed option. I did not like that answer because the dealer that I purchased it from did not give me the option. My local dealer installed it for free.
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
lbrjet
GM's are hot all the time, Ford's are hot only with the key on.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
Calicajun
After reading OP post, I went out and check my 7 pin connector. Luckily mine is working just fine. 🙂
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
LarryJM
Blue Hill wrote:
I had the same issue. I connected the wire and installed the fuse, but now the terminal is hot all the time, regardless of whether or not the key is on.
Be careful the trailer ckts might be different (i.e. fuze, fuze and relay, etc.) and how they operate (i.e. KO or KOFF) depending on vehicle make and even year. AFAIK Ford uses a relay and separate fuzes that operate independently of the other main electrical ckts and are not operable for KOFF status.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
Blue_Hill
2011 Gulfstream Streamlite Sport 25TSS
2011 Chevrolet Silverado 1500
Honda EU3000IS
MitchF150
oops.. Missed that you had the truck running.. Never mind.. 🙂
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
remdog_1
That's it, just install fuse and check with tester. When you test it the key has to be on.:)
ugh
enblethen wrote:
Wrong fuse. Check for another one. One in question is for charge only, I think the one you found is for the brake controller or the ignition control to energize the relay.
You are correct. I need to buy two more fuses.
2001 F250 5.4 3.73
ugh
RoyB wrote:
My 2010 Ford F150 had a envelope in the glove box with a 12VDC FUSE and RELAY in it with no instructions. Turned out these were required to be installed in the main fuse panel on top of the radiator to provide TOW VOLTAGE when the ignition key was turned ON.
That's it. The two relay was not installed. I found them in the glove compartment (hard to believe it was in there after 15 years) I just installed it, but it requires two additional fuses. I need to go buy the fuses tomorrow and test it.
2001 F250 5.4 3.73
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ugh
remdog*1 wrote:
Most trucks with tow package require a 20-30 amp fuse to be plugged in under the hood for the 12v to work. Check owners manual for location of the fuse.
I just checked. The fuse is in place and it is fine. It is not dedicated for number 4 pin. A/C clutch, power door locks and other things uses the same fuse.
2001 F250 5.4 3.73
RoyB
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
remdog_1
