Sep-07-2013 08:07 AM
Sep-10-2013 10:32 PM
dadmomh wrote:
The furnace in our ROO - Suburban, I think but can't be sure, did not have a filter in the air return, only in the ceiling unit. It was a sponge-type material. I just took it our 3 or 4 times a season, gave it a squirt of Dawn, squished it around and rinsed and dried. I recall someone who used a filter in the return even though the manual specifically said not to....I'd be leery of doing that. Our return on the ROO was under one of the dinette seats and it was a quick job to lift the plywood and vacuum it out. With our TT, it's under the cabinet below the kitchen sink, even easier to get to.
Sep-10-2013 09:19 PM
Sep-10-2013 05:12 PM
Sep-10-2013 01:40 PM
aepowell wrote:
I have never seen an air unit without a filter. My filter is filthy after just two campouts. Those thing suck a lot of air usually dusty air.
Sep-10-2013 01:28 AM
Sep-09-2013 08:16 AM
jpetrey wrote:
Walmart foam filter
Sep-09-2013 08:09 AM
dadmomh wrote:
Oops, I didn't thoroughly read the post above....you should definitely check with Dometic on a filter for that area. Some folks have gone ahead regardless and used one, but believe it would void any warranty you might have if adding one caused a problem.
Sep-08-2013 06:50 PM
Sep-08-2013 06:41 PM
Sep-08-2013 06:17 AM
Old-Biscuit wrote:
That woven material is 1" thick.........does it fit in the in return on your A/C Unit??
The thin foam material is what is typically used.
Sep-07-2013 10:24 AM
PeteK-Hou wrote:
I found some of this at Lowes
I now have enough for about 6 filters... 🙂
Sep-07-2013 10:04 AM
Sep-07-2013 08:33 AM
downtheroad wrote:
How about this? You can cut it to fit.....A/C filter LINK
Sep-07-2013 08:22 AM
