Feb-14-2014 07:02 AM
Oct-27-2014 08:44 AM
Feb-16-2014 04:43 PM
Feb-16-2014 03:38 PM
rv46 wrote:
@Bob Landry - I like your design. What is the parts # for the Blue Sea breaker and plate?
Feb-16-2014 02:42 PM
Feb-15-2014 07:44 AM
Bob Landry wrote:
I installed a Marinco 20A inlet and ran Romex to a small Blue Sea breaker panel that feeds two outlets that I use to run space heaters or fans as needed.
Feb-15-2014 07:02 AM
Feb-15-2014 06:42 AM
Feb-15-2014 06:01 AM
Feb-15-2014 05:40 AM
Feb-15-2014 05:39 AM
rv46 wrote:If you install a receptacle near the bathroom sink or the kitchen sink it will have to be a gfi receptacle or the c/b will have to be a gfi c/b. Also the receptacle will have to have the same or greater amp rating as the c/b you use.
I would like to add a dedicate outlet for high draw items (hairdryer, heater, griddle, etc.) The plan is to a add an inlet and route the wire directly to this one outlet. However, I don't want to solely rely on the breaker on the post.
I saw this in a hotel. I looked at HD, Lowe's and two local electrical distributors with no luck. I would prefer 15A/20A breaker.
Any ideas where to find this? Alternatives?
Feb-15-2014 04:43 AM
Feb-15-2014 04:27 AM
Feb-15-2014 04:06 AM
Feb-15-2014 12:28 AM
