โApr-11-2017 12:03 PM
โApr-12-2017 09:19 AM
seaeagle2 wrote:
Have you tried dimming the display, somewhere in the menu there should be a way to dim the display. On the dimmest, our Jensen isn't very bright.
โApr-11-2017 09:01 PM
โApr-11-2017 08:07 PM
danimal53 wrote:
I think I've got this all figured out, but wanted to run it by the good forum folks to see if I'm missing anything.
I want to add a 12v outlet near my radio, and a cutoff switch for the radio itself. I'm planning on installing this.
The switch will control the 12v outlet, radio, and voltmeter. The USB ports will stay powered regardless of the switch. I have full/easy access to the back of the radio, and all the wiring is clearly/neatly labelled (lucky me!). I also have the manual with wiring diagram if needed.
the radio is a Jensen jcd2010
So what I think I have to do is tap into the power going to the radio +12VDC BATTERY (memory) to power the USB (always on). Then the radio +12VDC SWITCHED (ACC) will go to my new switch, acting basically as the ignition if the radio were in a car. This will allow me to shutoff the radio so that darn superbright display won't keep me up at night, but I won't lose presets/clock.
Is it that straightforward or am I missing something? I've done a lot of house wiring/electrical, but never DC, so just double checking. I plan on using 12GA stranded wire and crimp connectors to tap into the existing wiring.
โApr-11-2017 07:57 PM
budwich wrote:
your " usb always on" maybe a problem IF you store your trailer "for a bit".... most usb "adapters" always draw power whether anything is plug into them or not. Hence there will always be a draw if you have no switch to cut power to it... sometimes "parasitic draws" can add up unexpectantly... ๐
โApr-11-2017 06:21 PM
โApr-11-2017 01:09 PM
โApr-11-2017 12:53 PM
โApr-11-2017 12:19 PM
westend wrote:
I think you have the wiring layout right. Ideally, I would want two switches, one to control 12V to the radio and one to control 12V to the power ports and the gauge but your circuits will work.
Do you know how to solder? In this application, a soldered connection may be more durable than a crimped connector.
โApr-11-2017 12:17 PM
Johno02 wrote:
Radio doesn't have a standard off/on switch that would do the job?? Otherwise, it sounds good from here. Might want to check fuse size on the radio circuit.
โApr-11-2017 12:14 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โApr-11-2017 12:13 PM
