Adding a backup camera to an Arctic Fox 1150
cdbinns
We installed a backup camera on our Arctic Fox 1150. We used a Ford camera and wiring harness so we could use the existing connector and display in our F350. Here's the finished product.
For more details on what we did, you can check out our blog post about the project. Camera Blog Post
1 REPLY 1
Crumm
I went a similar route but ordered up a ford camera, housing and emblem from Camera-Source. I mounted it directly under the camper bumper on a plate that extends up from the extended hitch. It's looks like it came from the factory. I will post up some pictures once I get done painting up the extension.
2015 F350 SuperDuty, SC, LB Torklift hitch and tie-downs, LT285/75R18 Toyo AT II 4080@80psi
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS
