Adding a rear "porch" to TC
ridesabout
Some time ago I saw and read a thread about adding a "porch" or extension on the rear of TC. I believe it was on this site. I have been unable to locate it after several searches. Does anyone know how to find it? I would like to see it again.
10 REPLIES 10
cleary
Here's a link to the post about my deck. CLICKY
Chuck
By the way, I've added tail lights to the bottom of the deck as it covers the camper's when folded up for travel.
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
JumboJet
I made mine so that it would fold up and also added LED brake/tail lights.
Golden_HVAC
I had a extendable bumper for my 75 F-350. It was basically the step bumper mounted to a pair of 2" square tubing. The tubing was mounted using pass through hitch mounts, welded to 3/8" plate steel, attached to the frame where one would normally mount a hitch.
So in the forward position, the step mount was near the tailgate, and everything looked normal from outside the truck. The 2" tubing extended about 24" in front of it's mounting hardware.
When you remove the hitch pins from each side, and pull out the bumper about 18", you put the pins back, and where ready to install the camper. In your case, if you can make it extend out another 12" or 24", you will have space for that patio.
Or you might want to make something that folds up while driving, and drops down about 9" to 12" below the camper step in hieght while parked. This will make it much easier to get into the camper while parked, and would be out of the way if you ever drove down a dirt road.
Good luck on the project!
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
pezvela
Sleepyhead, have you got some pics?
sleepyhead
Gosh it has been a long time since I have been on here. But I have my old porch forsale. I will fit right on to a lance.
Environmental groups ARE the local terrorist in the USA...................
Bill_T
Xtreme Campers in High Point, NC makes them.
Bill and Debbie
2007.5 SILVERADO HD DA CREWCAB LTZ 4X4 ARE CAP
2003 Nash 25S TT
2012 Lance 855S
1996 Coleman Taos pop-up
1970 jeepster,v-6
bobndot
seraphim
Go to the TC university thread. There are several listed there.
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902.
Itchey_Feet
Had to build my own, it bi folds up to the back of TC. Made it out of scaffold planks.
My feet are fine as long as they are traveling.
ManitouF
http://www.stripersonline.com/t/477969/porch-for-a-slide-on-camper
1997 Dodge Dually ExtCab Diesel, 350k miles on original cluth and still going, 5spd with Fuel Mods-TST 280hp/680FpT- 3.54 final. 235/85R16. EGT and boost gauges. 1993 Lance Squire 8000. Horses, or Harley's in trailer. Boat's.
