Unit arrived few days ago-tiny footprint but tall. Because it's so short looks even taller, I think our old one was about 10" this is 12 5/8", thats Tall. But it fits the available space we have, considerable less cost and at 72#, especially after turning it on yesterday pretty stoked. More stoked thats its done.
I didn't get a picture on the roof, it was too hot to uncover and get up there. Hid out in the shop all day. But reminds me the old air scoops they use to run on Vdubs, shark fin.
edit roof pics added at end One of the 'pre install items.
Not sure it was needed, probably non issue but I just didn't like the 32 screw holes from vent that would end up 1/2" from perimeter of AC gasket. So I wrapped with some 4" eterna bond tape. Local RV sells by the foot. Split into 2" strips for end and sides, cut front to 3" center taper to 2" on ends. Overlapped from bottom up. Thinking slight edge might help divert nightly fog from running and setting against the AC gasket. Again probably unneeded.
After AC done Im cutting a new hole to reinstall the Fan-Tastic Vent beside AC.
Last 'pre was reconnecting stub wire from ceiling AC pre wire connection box. Drilled a new hole to route closer to box of AC.
'Accidentally' got it on the roof yesterday. I was in the middle of loading camper and the AC stuff to take to friends. But getting the AC box into the camper it became apparent that wasn't going to happen. I had dead lifted from ground and sat on the patio railing. If I can lift it and carry into the camper it would be easier to walk up a ladder..so I tried not knowing if I could. Lifted from the railing onto 6', got on the 8' drug it over, then tilted the box toward roof, one shove and it was up there. I was amazed-been setting on it for 3 days.
And installed.
Not overly impressed with the way the inside unit interfaces, just different, primarily that is uses the vent hole thru roof and the ceiling as part of the distribution box. It uses a foam block that divides the 14" hole. At least Im use to an interior metal box thats is fed by duct between the top & inside units. Works, part of the cost reduction I assume. I sealed & lined the 14" (wood) vent hole with aluminum tape. As this will only be used infrequently maybe a couple of times a year not really that concerned. Otherwise if used a lot easy enough to cut a piece of sheet, box and duct.
Pretty easy install once the unit on roof. Couple of snafus, mostly operator error. The whole time I was getting ready I had the orientation of inside shroud 180ยฐ off. With the divider and inside metal in place, umm Im scratching my head 'why is the 110V on the wrong side'-looking thru instructions no mention of how to get thru divider to 110v box to connect, hey that 'front' is... :S Dohh...
Took it apart, pulled and rerun my new prewire that I had rerouted to what I thought was closer back thru original hole in vent hole.
Second was my new clicker inch pound wrench. It doesn't audibly click, at least at lower settings lower than 50. Fortunately I started out at 20, I realized this seems awfully tight and not clicking and took to shop. Figured out its not audible, handle kind flops. Rechecked the ac and I was up to 35 before I noted the handle indication. Rerun to 45 inch pounds.
Other than that pretty quick. Bolted down, I connected the wiring. I had pulled the inside ceiling panel trim. Im cutting to fit so inside shroud sets flush against ceiling.
Install the shroud and turned on. Surprised, It is way quieter that our old coleman. Walked in the house to get a cup of coffee, back to the camper I open the door... wow.
Dropped from 82ยฐ to 67ยฐ in time it took to go get a cup. The 80ยฐ is inside refer. Pretty cool, literally, the air output on our old unit was never as cold. Though only 82ยฐ I hope this is indication of what we might expect. Margaret is excited.
Have 10" between the AC and solar panel so shouldn't see any shading, I can walk by. I don't think for most, due to its height the Brisk ll a good choice on a TC but its a nice unit and only viable option in our case.
Last detail was the knobs. The have a little bump that is indicator. Hard to tell which way its pointing once knob is turned.
Used a small ball end on Dremel, filled with paint-that'll work.
Other than getting AC up on the roof, only real work is cleaning old vent hole if replacing a vent.
Next reinstall the Vent beside the AC.
