โOct-18-2015 08:27 PM
โNov-11-2015 05:28 AM
โNov-10-2015 02:25 PM
Golden_HVAC wrote:
Your 'basic' load on the camper is 35 amp hours a day to run the refrigerator, CO detector and propane leak detector. This is about what your 100 watt solar panel will make on a good day. So don't be to surprised if the solar barely keeps up with the loads placed on it.
Yes the second panel will come in handy to keep it full. Yet even the 100 watt system will keep the battery full all the time if you have the Propane detector off, and refrigerator off. This really helps out and keeps the battery at it's full amp hour rating all it's lifetime. .
Fred.
โNov-10-2015 02:05 PM
โOct-20-2015 03:20 PM
mpoulsen wrote:I have a 2002 Okanagan 5er. The solar wiring came up through the roof with the TV antenna cable. The other end terminated in the basement. 2 - #10 wires. I had no panel.
So I don't have to remove the panel that the sticker says "prewired for solar"? I assume I should find the wiring near that location
โOct-20-2015 03:08 PM
โOct-20-2015 10:23 AM
โOct-20-2015 08:30 AM
โOct-20-2015 08:29 AM
mpoulsen wrote:
......I have a 2000 watt,4000 peak,2000 watts is max 18 amps I would like to install it just in case (I like options and gadgets) but it's so large where to mount it?......
โOct-20-2015 07:30 AM
โOct-20-2015 06:05 AM
โOct-20-2015 05:26 AM
mpoulsen wrote:
I have a 2000 watt,4000 peak,2000 watts is max 18 amps I would like to install it just in case (I like options and gadgets) but it's so large where to mount it? So where do most of you mount them,it has three 110 outlets. If I used it or try it to see how things did the Keurig coffee maker would be the big one at 14amps
โOct-19-2015 08:10 PM
โOct-19-2015 09:35 AM
billtex wrote:bigfootford wrote:
1 100ah AGM Lifeline battery.
We have led lights, a wave 3 heater, LED tv.... We use 15-20 ah a day.
We only use the furnace for quick warm up, It gobbles battery amps.
We watch tv about 2 hrs a night, read for an hr or more, charge our laptops/cell phones etc.
Unless we are in a dense forest or dead of winter and heavy cloud cover we easily recover our used AH by noon or better.
We do have our honda 2000 if needed.
We do not charge from the truck although I can... Just throw a switch.
Jim
That is a LOT to ask of 1 battery...if you upped your available amp hrs you would be better off.
โOct-19-2015 08:31 AM
Jim
