Additional fuel tank
djcjc
I have a 2021 Ram dually DSl mega cab just bought our first fifth wheel Jayco 347 BHOK which is 42 ft long last TT was 36 ft long so length behind truck not much different but would like to add a seperate fuel tank to the bed of truck looks like smallest i can find right now would be about 38 gallons which would be ok. My thoughts are putting in back of truck next to front of bed would like to run a line to gravity feed into existing tank with a valve that i could open when tank gets towards empty. With that setup I could run all day without trying to find a gas station with easy in out for this long of a rig. Hope would be to find stop for the night set up unhook and go get fuel without rig behind. Anybody done this or having any idea's on my thoughts. The big 50 gal tank is not an option for the megacab shortbeds.
22 REPLIES 22
valhalla360
Nomad III
Nomad III
Cummins12V98 wrote:
Simply donโ€™t get this get to camp after a long day and go get fuel. Simply hit the truck stops.
If you are doing back to back to back travel days...sure.
If you stop for 2-3 days between runs, not being limited to truck stops is nice.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Bionic_Man
I put a 60 gallon RDS auxiliary tank into my truck when I bought it new 10 years ago. For me, it has been one of the best upgrades I could do to a truck. When I finally upgrade from this truck, I will 100% do it again.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
larry_barnhart
Our 55 gal inbed fuel tank has worked great for us as above feels. best thing is we had it built when our 05 truck was new. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
fj12ryder
Getting an auxiliary fuel tank is one of the best things you can do. It becomes the scenario where you stop when you want to, not when the truck demands it. If you never travel off the interstates, it's less of an issue, but get off on the two lanes and those big ol' truck stops are fewer and farther between.
Personally I'd rather stop at a city park, rest stop, or almost anyplace rather than spend time at a truck stop. And my long day of travel is about 250-300 miles. ๐Ÿ™‚ I can usually travel two days before I have to refuel.
I believe the newer versions of the injector pumps are very intolerant of any water or rust, so you may be better off using an aluminum tank. I have a 35 gallon steel tank, and it is the perfect size for me, but I also have an old diesel engine that isn't as fussy as the new ones.
Howard and Peggy
"Don't Panic"
FishOnOne
If you want more capacity get a TITAN 50 gallon replacement tank. Then you still have room for a toolbox.
What is DSI ?
DSI = Diesel
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Lwiddis
OK but once I get to my campsite and setup, I want to stay in my campsite.
Cummins12V98
What is DSI ?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Grit_dog
Navigator
Navigator
No issue with what youโ€™re proposing. Itโ€™s very common. The most convenient way is to make it full time gravity feed with a check valve.
Just buy a gravity kit from one of the popular mfgs for ease of install.
