Aftermarket wheels
milleda31
Gentlemen,
I have a 2016 Ford F350 Lariat LB DRW and a 2008 Lance Max981 camper.
Suspension and current wheels and tires are all stock (Alcoa wheels). I want to switch out the wheels and tires for some aftermarket 20" Fuel's or Vision's. The ones I like require no spacers. The Fuel's are rated at 2500 lbs. and the Vision's are rated at 4300. I would be mounting some Toyo Open Country tires on them.
Clearly the Vision wheels will handle the weight. What do you think about the Fuel's? Also, I sometimes pull a 3500 lbs. boat behind the setup. All my truck gear is Torklift. Camper probably right at about 4000 lbs.
Thoughts? Thanks in advance.
https://www.visionwheel.com/wheel/7210/VisionHDTruck/Trailer/401%20Rival?finishID=591
http://www.fueloffroad.com/wheel/11115/fuel%2Ddually%2Dwheels%2Dtriton%2Ddually%2Drear/?finishID=329&lugs=8
2016 Ford F350 6.7 PSD CC LARIAT DRW
Tork Lift tie downs/FastGuns/SuperHitch
Vision 401 Rival wheels, Toyo ATIII tires
2007 LanceMax 981 Fully loaded
35 REPLIES 35
Grit_dog
Nomad III
Nomad III
Yes the visions blow any capacity concerns you might have right out of the water.
By the same token, the 2500lb wheels will be fine, imo. The fronts will be right at or marginally over, but you’ll have 10klbs min cap on the rear, assuming you’re inner dually wheels are rated the same or more.
If thinking long term, I’d go with the visions.
milleda31
3 tons wrote:
First off, Safety matters and the majority of the ‘racy’ aftermarket wheels out there are of the cheap cast variety designed more for looks rather than loads - go forged like your robust Alcoa’s and stay Safe...
3 tons
Agree 100%
I used to haul my Lance on a 2001 F350 7.3 SRW. I upgraded the wheels on that vehicle to Vision 19.5" rated at 3900 lbs. I also ran load range F tires on it.
https://www.visionwheel.com/wheel/867/VisionHDTruck/Trailer/81A%20Heavy%20Hauler?finishID=103
The Visions in my first post are rated at 4300 lbs. and add the fact that my current truck is a DRW. I am assuming that I'm good to go, correct?
3_tons
3 tons
jimh406
I’d look at American Force wheels, and also consider 22.5s.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
milleda31
jimh425 wrote:
First, what is your goal? Are you simply trying to make your DRW look cool or something else?
Yes...simply for appearance.
jimh406
