โMay-16-2014 09:24 PM
โMay-25-2014 05:13 AM
โMay-21-2014 03:01 AM
sky_free wrote:thejustin wrote:
Dropped off truck this morning for lower stableloads and airbags, dealer calls me and says there is a problem. Apparently, with the spacing that is in their and the way they would have to be installed, I would have to jack up the entire rear end of the truck every time they needed to be engaged or disengaged in order to obtain the required clearance to slide them in and out of place. Kind of defeats the purpose of having the "quick disconnect" feature. Little bit bummed about that.
So, we are proceeding with just the airbag install. Hopefully I won't have much sway. May have to do the bigwig sway bar next instead of the shocks. We'll see how she drives.
I see that the airbags are working out for you, which is great. I wanted to comment on this even though it's not needed now.
When I installed the lower stable loads on my truck (which is the same as yours), I was able to use 3 wedges on the back and 2 on the front, while still having enough room to "quick disconnect" them without jacking the back up. Your guy probably was trying to put all 3 on the front and realized it would be a problem.
Later, since I always carry the TC, I decided to just put all 3 on the front too. If I wanted to disconnect them, I would have to release a little tension by quickly jacking up the back via my floor jack on the hitch. Takes a couple of minutes for me to do that, so no big deal. It would only have to be lifted a few inches, which is what I did to install them. Definitely not all the way up with the wheels off the ground. Didn't even do that when I installed them.
Glad the air bags are working out for you. I'll probably do that next myself when funds are available.
โMay-20-2014 11:52 PM
โMay-20-2014 09:51 PM
MORSNOW wrote:thejustin wrote:
I drove 50 miles from Anchorage out towards Portage and it handled beautifully. Absolutely zero sway so I'm guessing I have the perfect amount of air in each bag and its not over inflated. The truck felt much more solid, especially maneuvering around the tight gas station out in Girdwood. I did notice some bucking when I hit some dips so I think I'll forgo the hellwig for now and do the Rancho's. Rides very comfortably now and its level. I am a happy camper.
Great to hear you got the setup that works for you! I can relate to the crazy freight charges and frustration in finding vendors who are willing to work with you on alternative shipping. I've had pretty good luck contacting vendors and requesting they ship to Alaska using USPS Flat Rate boxes. See you on the road this weekend!
โMay-20-2014 09:40 PM
โMay-20-2014 08:53 PM
msiminoff wrote:thejustin wrote:
Does anyone out there run the uppers lowers and airbags at the same time and have any experiences with the ride quality?
I run run airbags and extended upper and lower overload bump stops that are nearly identical to upper/lower StableLoads This combination offers great ride quality and allows me to keep the pressure in the airbags to 25-30psi or less. Of course my truck is a RAM so YMMV.
Note that you should run your airbags at as low the minimum pressure that will restore your desired ride height. High airbag pressure causes a harsh ride due to them having a rapidly rising spring rate.
Cheers
-Mark
โMay-20-2014 08:40 PM
Nautique200 wrote:
install the RS9000xl and run them at 3 when empty and then crank them up to 10 when loaded with the camper. Huge difference!
โMay-20-2014 04:05 PM
โMay-20-2014 02:52 PM
โMay-20-2014 01:47 PM
ah64id wrote:thejustin wrote:ah64id wrote:
I think you will be better off with a big wig anyhow...
Looking for somebody online that will ship to Alaska. Amazon doesn't have the one I need. ๐
Isn't is a 7271?
http://www.amazon.com/Hellwig-7271-Rear-Sway-F-250/dp/B006J1ASZ6/ref=sr_1_4?ie=UTF8&qid=1400615501&sr=8-4&keywords=hellwig+big+wig
โMay-20-2014 12:55 PM
โMay-20-2014 12:46 PM
โMay-20-2014 12:37 PM
โMay-20-2014 12:32 PM
Bedlam wrote:
Mine are tight, but I can inflate the airbags to take pressure off. You can also use 1, 2 or 3 wedges per StableLoad if you have less clearance.
