Dec-09-2017 07:47 PM
Dec-11-2017 04:20 PM
joelyn wrote:
Thanks to all for some good advice and suggestions. REDDOG some very good info. thanks.
will probably go with the airlift wireless but not in a hurry so will keep a watch for some sales that might be going on during xmas.
THANK YOU ALL AGAIN, MOST APPRECIATED.......
Dec-11-2017 11:01 AM
Dec-11-2017 10:16 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Dec-11-2017 09:07 AM
Dec-11-2017 09:00 AM
Toad: 91 Zuke
Dec-11-2017 07:29 AM
SidecarFlip wrote:
I will say that while my Air Lift compressor is an earlier (wired version), it's been in use for around 15 years now on my 1997 Ford 350 and I've never had any issue with it at all. I have the under dash mounted pressure gauge and the rocker switch to increase the pressure plus an air release to lower it if I want to.
I'd say 15 years of use without any issues is a good testament to it's longevity.
Mine has an adjustable pre set to maintain air in the bags at all times which is necessary to keep the bags from getting kinked between the upper and lower pedestals. I have mine set at 5psi but it is adjustable. Original bags too and they show no sign of cracking or deterioration.
Mine is inside the cab, mounted behind the back seat. I'm very happy with the entire system and have been for a long time.
Yes, I installed it myself a long time ago. Not hard really. All the fittings are push to lock, just a matter of curring the syn-flex tubing to length and securing it to the frame.
Dec-11-2017 06:03 AM
Dec-11-2017 05:39 AM
Dec-11-2017 04:57 AM
Dec-11-2017 04:41 AM
Dec-10-2017 06:16 AM
Dec-10-2017 06:09 AM
Dec-09-2017 09:01 PM
PatrickA51 wrote:
This is just my opinion. You can purchase a Viair 12v DC compressor on Amazon or at 4Wheel Parts Warehouse. They are less than $200.00 Dollars on Amazon
Viair 400P on Amazon.
Dec-09-2017 08:00 PM
