- djsamuelNomad
Bumpyroad wrote:
i thought I had read here where camplites went to a wooden floor because of complaints of cold floors when they were aluminum. I would have bought one of them instead of my ascend if their small ones had a decent sink/vanity in the bath.
bumpy
They went to a non-wood composite floor. Some who own them seem to like them so far. The floor in my Camplite is aluminum which I like, but it does get cold at times. Here is info from Camplite regarding the floors:
· Absolutely NO WOOD in the super structure, including the floor system
· 5 layers-We use 5 layers to construct the floor. Lamilux fiberglass top, 1-layer of Azdel, polystyrene(High-density block foam insulation), lastly another layer of Azdel and Darco protective wrap
· Most laminated floor systems use wood product called luan, LL DOES NOT use wood. We have thoroughly tested(weight per sq inch) this new and improved floor with the fiberglass top layer. it has outperformed the luan constructed laminated floor system used by many manufacturers in the RV industry.
· Aluminum framed floor. R-value is 10 VS previous way was R-0
· Heat/Cold transfer is less do to the insulated floor over the aluminum floor
· High-density Block foam adds noise reduction
· More comfortable to stand on, Smooth fiberglass top, no ridges like the aluminum floor system
· This new advanced floor is lighter weight than the old floor system. - BumpyroadExplorer
djsamuel wrote:
Atlee wrote:
Wasn't aware of Camplites. But they'd be in the same class as Airstreams then.
What most folks are talking about when referring to aluminum siding are the RV's that have the aluminum siding sort of like a house. Those siding types have wood frames.
Thanks, understand. I figured that is what you meant and agree. I just wanted to mention another type of aluminum sided trailer that some may not think about. The siding on the Camplite is smooth and very rigid; much different than the house like siding you mention.
Thanks again for the clarification. :)
bumpy - rbpruExplorer IIAnother issue to keep in mind is both aluminum and fiberglass are popular but both depreciate rapidly. The outside skin seems to make little difference.
Except for Airstream and a few other unique brands which have an almost cult following, the outer shell and the roof material seem to be immaterial.
I do not recall anyone getting more for any specific TT construction, no matter what the dealer says. - 1stgenfarmboyExplorer
rbpru wrote:
Aluminum is older technology affectionately called stick and tin. It is well established with several generations of design, construction and repair history.
Fiberglass is a newer technology. Though also a couple of decades olds, the technology continues to evolve. Fiberglass lends itself to the fancy shapes and sculpted designs that folks like, plus it offers a broad canvas for today's artistic decals.
Aluminum is prone to dents, fiberglass is prone to de-eliminations. Which is better is mostly a matter of opinion or unusual circumstance such as the aforementioned hail or intense sunshine.
In my humble opinion, the floor plan and interior components far outweigh the exterior covering.
Good luck
this is what we did, we found one with all the things we liked and bought it, but I prefer the metal for durability, but the fiberglass for looks - djsamuelNomad
Thanks again for the clarification. :) - AtleeExplorer IIWasn't aware of Camplites. But they'd be in the same class as Airstreams then.
What most folks are talking about when referring to aluminum siding are the RV's that have the aluminum siding sort of like a house. Those siding types have wood frames.djsamuel wrote:
Atlee wrote:
I believe you're wrong here. If an RV has aluminum siding, it's almost 100% sure to have a wood frame. Not counting Airstreams of course.
None of Jayco's aluminum sided trailers have aluminum frames. They all have wood framing.
Camplites have aluminum frame and smooth aluminum siding. - modern_familyExplorerOne of the biggest differences I noticed was that the siding is a less rigid unit. For example, when lowering my stabilizer jacks, I have to be very cautious as to how tight I make them. I hear all types of noises and cracking as the unit easily twists and you can place your unit / doors out of square quickly. I never had this issue with my previous fiberglass TT.
- djsamuelNomad
Camplites have aluminum frame and smooth aluminum siding. SidecarFlip wrote:
It's very difficult to repair if damaged, really the only repair is panel replacement....SidecarFlip wrote:
Looks like you provided your own rebuttal.
...I never said it could not be repaired. Anything can be restored/repaired ...- valhalla360Navigator
None of Jayco's aluminum sided trailers have aluminum frames. They all have wood framing.valhalla360 wrote:
A little correction: Most new RV's regardless of siding use Aluminum studs not wood, so having aluminum siding does not mean you will have wood studs that will rot.
Of course, water inside the walls is a bad thing no matter what construction method is used.
Odd, my Dads, brother-in-laws and my previous aluminum sided trailers all had aluminum framing.
But again water inside ANY wall is a bad thing. If you walk around a campground, almost every fiberglass sided trailer over 10yrs old will have at least some delamination.
About Travel Trailer Group
44,068 PostsLatest Activity: Jun 01, 2026
