โAug-28-2017 08:10 AM
โAug-29-2017 08:27 AM
โAug-29-2017 07:31 AM
adamis wrote:Redwoodcamper wrote:
I used the renogy 200watt kit with normal panels and used eternabond to tape them to the roof. Been 1000+miles and over 80mph on occasion with them not moving.
Thanks for the report. I do have a question about the eternabond tape you used. Do you have any concerns about being able to remove it from your roof should the panel ever need to be replaced? I have a fiberglass roof and though I'm confident the adhesives will hold, I am a bit concerned about what damage it may cause if it ever needs to be removed.
โAug-29-2017 07:25 AM
work2much wrote:
I don't have experience with these panels. If you are only looking for 100 watts of energy you may want to consider a portable folding system that you can place and angle into the sun rather than a roof top install.
Like this
https://www.amazon.com/ECO-WORTHY-Portable-Polycrystalline-Foldable-Suitcase/dp/B00MGLIIQO/ref=sr_1_...
From what I have read the thin flexible panels aren't very efficient and once placed on the roof have no way to ventilate off heat from the backside which further reduces their efficiency.
โAug-29-2017 06:59 AM
Like this
โAug-29-2017 06:24 AM
โAug-28-2017 11:23 PM
โAug-28-2017 09:10 PM
โAug-28-2017 10:35 AM
โAug-28-2017 08:13 AM
