Dec-01-2019 04:20 PM
Dec-11-2019 05:00 PM
Dec-10-2019 07:48 PM
garyemunson wrote:
Do not have a glass shop make a cover to save a few bucks. Those must be tempered glass for safety...shops cannot cut tempered.
Dec-10-2019 05:05 PM
Dec-05-2019 05:17 PM
Dec-02-2019 05:30 PM
Dec-02-2019 05:26 PM
Grit dog wrote:
"While I am sure no one has done something like this, but maybe you have helped someone who has?"
Ha love this!
Just like when someone is asking, you know, "for a friend!"
Hope you get your cooktop fixed. Cheers!
Dec-02-2019 05:23 PM
DutchmenSport wrote:
For the OP? Question?
Help me understand. Was the burner turned on while the glass cover was closed?
What you were saying is, you didn't realize the cover was closed when you came in from the outside and fired up the stove? So the flame making contact with the glass cover caused it to explode?
Question also? Was the camper cold? Like freezing inside? So when the flame touched the glass, the glass was... like 20 degrees and then instantly getting hit with fire causing it to explode, or was the camper already heated inside when you entered? Either way, the flame made contact with the glass?
Reason I'm asking is because I have a Furrion stove also with the glass flip back-bi-fold cover. I've often wondered, what would happen if the cover was left closed and the burner turned on?
I would have imagined that glass would have been heat and fire resistant. But... maybe not?
Our previous TT did not have a cover at all. I used a large wooden cutting board. Never had a problem using that. It had a cork pad attached on the bottom which prevented sliding around on the burners while in transit.
Here's another suggestion if you can't locate another glass top:
Click here.
Dec-02-2019 05:07 PM
ggardne2 wrote:
Is thsi what you are looking for?
Furion Top Glass
Dec-02-2019 04:34 PM
Furion Top Glass
Dec-02-2019 04:29 PM
Dec-02-2019 04:11 PM
Dec-02-2019 07:03 AM
Dec-02-2019 06:33 AM
Dec-02-2019 05:38 AM
schlep1967 wrote:
Just my opinion but .... DO NOT PUT ANYTHING ON THERE THAT WILL BURN. Those saying to put wood on there, very bad idea. A burner gets turned on under the wood next thing your camper is on fire. Either replace the glass or make a cover out of sheet metal.
