All battery/electric bus fleet
colliehauler
On Thursdays Wichita KS will convert it's bus fleet to all battery/electric bus fleet. With set routes and know range I think this is a wise use of a electric vehicle.
32 REPLIES 32
RobertRyan
rjstractor wrote:
JRscooby wrote:
I would thing school buses would be a good fit. Charge overnight, then if needed, some charge in the daytime between runs. Maybe solar on the roof of bus to do a little daytime charge?
Electric school buses are already on the market. With a 155 kwh battery they might offer enough range for typical school district usage. When I drove bus many years ago a typical bus would do about 7 or 8 runs a day, with a total distance of 80-100 miles per day. The claimed 120 mile range would work on a good day, but during cold, rainy weather power use would climb. There's a couple hours of down time during the day where buses could get a little "bump" to their batteries. A 200 kwh battery might give enough range to make the buses a little more practical. Upgrading the electrical systems at the bus barns would be a significant expense that school districts might be reluctant to invest in.
Electric Buses are already running around Australia, this is a Chinese based one, but SEA an Australian company has an order for 200 of its step in Vans from the US
Volgenest largest Australian Bus maker goes Electric
RobertRyan
DutchmenSport wrote:
Indianapolis just did this, and when weather got cold, they failed.
Good luck!
Edit:
I just checked, the article is till out there. Click here.
Another... Good luck!
Talk about cold, Kamaz in Russia, has Electric Busess running around Moscow
Kamaz Electric Buses
Reisender
The uptake of EVโ€™s is currently higher in cold climates than warm ones. For us EVโ€™s are considerably more convenient than liquid fueled vehicles. But, everyone has different needs. Buy what suits your needs.
wilber1
Edmonton is buying 50 electric buses. -30C winter temperatures are not unusual. Interesting.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
JRscooby
Yes, would need to upgrade power to barn. Of course one of my rants is parents that need to load kids in car, and set at the bus stop. Bet in my area it would average 3 cars idling all the time bus is running...
rjstractor
2017 VW Golf Alltrack
2000 Ford F250 7.3
time2roll
Good luck!
Edit:
Theres that Chinese quality again
Buy Canadian next time
https://www.nationalobserver.com/2019/03/21/news/many-canadian-transit-agencies-are-missing-made-canada-electric-buses-says-new
Failure seems a bit strong by what is written in the link.
free_radical
Good luck!
Edit:
BenK
Easy, or at least to my thinking...
Known issue with any battery's performance in low temp operations.
Then manage to that
  • Increase battery capacity to account for their drop in performance
  • Heat the batteries
  • Instead of all of the suggestions on powering them along the ride...just have plug-in stations throughout their route
  • supplement it with on-board ICE's during the winter months
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
colliehauler
Could be if they have enough range in winter.
JRscooby
time2roll
Grit dog wrote:
LanceRKeys wrote:
time2roll wrote:
Best way to gain knowledge is to get out there are do the impossible. Fear of failure and setbacks holds too many people down in life.
Reply of the year.
......on the taxpayers nickel.
Good chance it will be a nickel saved for the public. Do you have comprehensive information otherwise?
More fear factor and FUD.
Grit_dog
Navigator
Navigator
LanceRKeys wrote:
Reply of the year.
time2roll
Inductive is closer to 80% to 90% efficient depending on how well the target can line up.
Yes conductive can be used. I have read a reverse pantograph has been successful. These would generally be deployed at one or two stops on route where the driver takes a break. Guessing close to 200+ kW for 15-20 minutes. Not to fully charge but to extend the range.
