Another White RimTrail TR
cewillis
I drove and camped on the WRT in mid-June. I chose that time to have dry weather, and a small crowd -- got both. It was ~ 10 degrees hotter than the advertised average high of 93, and didn't cool to 80 until ~10pm. Didn't bother me.
The WRT is often described as 'moderately difficult in good weather'. I'd say it's primarily just a slow drive; e.g., 35 miles in 9 hours. Many sections are rough, or steep, or narrow, or deep sand, or badly rutted, or have sharp turns, or some combination - but it is not really very difficult with respect to any of those conditions (could be much worse in wet conditions).
For anyone interested in my equipment setup, it's here.
Here's a great map of Canyonlands and the surrounding area.
My amateur panorama from the Grand View Point Overlook (way above the WRT) is here. (too big too post here)
I'm posting a good sample of pictures here, and may add more. For anyone interested, my web site has more info and ~150 larger pictures.
I stopped overnight going north at the Goosenecks of the San Jaun. (thanks, Dave)
The WRT from the Grand View Point Overlook.
Starting down the Shafer Trail to the WRT.
At the bottom
The Colorado River
Airport Tower -- 1st campsite
A section of 'paved' road.
And not paved
Napoleon addressing his troops
Approaching the (in)famous 'Murphy's Hogback'
That must be it
Looks like an ordinary little hill to me
And down the other side
'The' overhang? An overhang. More than 2 feet clearance.
Good look at the Green River.
Which also has a gooseneck
This is about as rough as the road got -- so not very, if slow.
A Ford 3500 dually flatbed pumper. This is between Murphy hill and Hardscrabble hill. So how bad can the road be?.
On Hardscrabble Hill
Near the top
Here's what it looks like. One turn was too tight for me. There are wide turn areas at three corners.
Pretty nice views around here
Hardscrabble B camp area - quite nice.
This is a big river. Lots of splashes out there, too.
Finally found the nearly hidden river access - would be better without so much Coyote Willow and Tamerisk.
The bank is steep and slippery, and the mud is very soft -- sink right in.
A little sand --
Labyrinth camp area -- near the Mineral Bottom exit. Also nice.
Wanna wind up in the Green River? Don't pay attention through here.
OK -- but a dually flatbed can make it.
Now come on! The road is rougher than that. Near the Mineral Bottom boat ramp turn. There were dozens of kids over there - about to start or just ended a canoe trip.
Mineral Bottom switchbacks. Had to back up here to let a van and canoe trailer by. Then wait as at least a dozen Suburbans and a few trucks pulling empty canoe trailers went by. See the bus?
That afternoon, 10000+ feet in the Manti-La Sal NF. Temp: 75 at 4:30. 25+ degrees lower than on the WRT.
Think I'll stay here.
Stopped at Muley Point on the way home.
Panorama from Muley Point.
Cal
28 REPLIES 28
cewillis
Thanks for the compliments. I forgot to summarize the trip. Scenery outstanding, camping adequate but not a reason to go back; road conditions pretty mild. Hardscrabble B is the best site in my opinion, and Labyrinth would also be nice if not much traffic.
Don't mean to step on any toes with my description of the road as fairly tame. Honestly, I had a little trepidation based on other descriptions of the road and the various warnings on the Canyonlands site. But I described it as I found it in the dry, uncrowded conditions I had (by plan). I said it could be much worse when wet.
For instance, currently on the Canyonlands site:
White Rim Road: open with some significant flood damage.
Lathrop Road: impassable after two miles
UPDATE โ€“ July 13, 2015 โ€“ Recent rain events have heavily impacted certain sections of the White Rim. Significant impacts occurred mostly in wash bottoms between Murphy Hogback and Airport, including Lathrop Canyon. One occurrence of rockfall on Murphy Hogback has created a significant barrier to four-wheeled vehicles attempting to drive the White Rim in its entirety.
It would also be 'undesirable' if much backing up for traffic was required in the narrow places .
Bicycles: If you ride this road in the summer, you're a much better man than I -- or flat out nuts. Or both.
Narrow spots and overhangs: No, there is no bail out room. You either fit, or you back out. My camper is 7 feet wide, and the mirrors stick out to almost 9 feet. I didn't pull in the mirrors, and never touched them on any obstacles, but it was very close. As you can see in the pictures, my Apex 8 basement popup (travel height approximately 8'-9") cleared the lowest overhang by about 2 feet.
Hardside campers: As I read the TC trip reports, NedRierson78 is the only one here who has made the entire route in a hardside camper, although C.Traveler2 got close by by combining two trips and starting in different directions. Please correct if mistaken. So it can be done. The two tightest places are between Hardscrabble camp area and Mineral Bottom. So if you're concerned about making it, I'd suggest starting at Mineral Bottom, and walking the tight areas first.
Wheelbase: Obviously, shorter is better for the tight turns. My wheelbase is 143", and I had to make one 2-point turn. However, there are large turn areas at every really tight turn that I remember.
silversand wrote:
....this one slipped by me!
And many say 'You can't slip anything by ole Silver'.
And finally,
67avion wrote:
I know Dear Jane would flat get out and walk back....and I'd have to go on without her ;-(
You are TOTALLY on your own with that situation, Sir.
If more questions, let me know.
Cal
c_traveler2
Nice WRT report like with many things back road conditions can change with the weather. Our first trip down the WRT took us all day just to reach Airport campsite, the trail was that rough. The OP adventure shows how the same trail can change from one adventurer journey to the next trail blazers experience on the same trail.
2007 F-250 4x4 /6.0 PSD/ext cab/ 2020 Bunduvry
Lance 815/ 85 watts solar panel (sold)
2020 Bunduvry by BundutecUSA
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
jefe_4x4
Good report and pix. A lot of old friendly locales here. It looks like you were solo. What? No selfies? I guess those legs in the mud could be considered a selfie in TC-land.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
silversand
A lot of forethought, it appears, went into choosing your "weather window". This made for a very smooth "expedition" through terrain that could have otherwise been a hellacious slog.
Excellent report!
S-
Silver
2004 Chevy Silverado 2500HD 4x4 6.0L Ext/LB Tow Package 4L80E Michelin AT2s| Outfitter Caribou
joerg68
Nomad III
Nomad III
Very cool! Nice Driving... And the landscape - gorgeous as always.
Certainly better than the view out of my office window ๐Ÿ˜‰
Thanks a lot for taking me along, TR-wise!
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
sabconsulting
Wow, you are so lucky to have all this on your doorstep.
Thanks for the report.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'98 Jeep TJ 4.0
'15 Ford Fiesta ST
'09 Fiat Panda 1.2
nycsteve
Very nice ,thanks. I would have trouble with the overhang I think. Unless there was enough room on the side to slip around. Is there?
The_Mad_Norsky
TCinmydreams40yrs wrote:
Kinda new here, but..
Real nice!
I went to Canyonlands site and was disturbed that you can't take pets.
Darn.
Tom
Ouch. Thanks, just looked too for curiosity.
From Canyonlands website: Pets are not allowed on any hiking trails or in the backcountry, even on a boat or in a vehicle.
Guess that takes WRT off my bucket list. Shoot!
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
TomP40
Real nice!
Darn.
Tom
2007 F-350 4X4 SB Lariat 6.0 Powerstroke, bullet proof upgrades-EGR, remote oil cooler, stand pipes &dummy plugs, blue spring, water pump, STC fitting...
1997 Lance Squire 3000-My first Truck Camper
CptnBG
Excellent!! Canyonlands is on my short list. Although I won't be able to do the North Rim on an upcoming trip, your report is very helpful. And thanks for the map! Very detailed.
'03 2500HD CrewCab SB 6.0 Gas 4x4
'04 Northstar Laredo SC
Bilsteins 5100
2014 1500 Silverado 5.3 Double Cab
1951 Chevy 3100
Formally OBXcamper
trackhead
I've done the White Rim a couple times on the moto, and the bicycle, haven't gotten my family down there yet. Would love to when we move back to Utardia.
Thanks for posting.
GoinThisAway
Great trip report. Surprisingly green down along the river. It's always amazed me that one can go from the shot depths of the canyons to the cool heights of the LaSals in a one day.
2008 Dodge 3500 DRW 4x4
2008 Bigfoot 25C10.4
Torklift/Fastguns/Hellwig/StableLoads
F350mule
Nice pics! Hope to make it out there again maybe next year.
2001 F-350 Crew-cab 4x4 2001 Lance 1010 Life is good
Stormpeakco
Nice pics and an Epic trip on a bicycle.
I've done it during a 3 day/2 night sojourn but know of people who have ridden it in one. I would think in a vehicle it would be tougher than on the bike, rough road.
