Dec-13-2021 07:20 AM
Dec-15-2021 07:19 PM
Dec-15-2021 03:35 PM
Dec-15-2021 01:40 PM
ZR1 wrote:
ivbinconned, don't give up just yet. The issue of a failure of a transmission cooler in the radiator is a common problem for GM. The real issue how long did it go before you discovered the problem. In many cases you can simply replace the radiator, have the transmission flushed and the fluid replaced and you may be good to go. This is something you may want to consider before you just give up and purchase a transmission rebuild. Ultimately if the transmission has been toasted you can have a GM dealer replace the trans with a factory rebuild and you will get at 3 year 100k warranty to boot. Do your homework before you give up. You have lots of options!
Dec-15-2021 01:34 PM
Dec-15-2021 01:16 PM
ZR1 wrote:
...Its sad GM decided to go with there new 10 speed "Branded" Allison in their new trucks, it's really not an Allison since they did not build or engineer it. If Dodge gets the new true Allison 9 speed this will be a game changer for them and I think many will jump brands to get it.
Anyway, Cheers, glad to see your back on the road again!
Dec-15-2021 11:22 AM
Dec-14-2021 07:17 AM
Dec-14-2021 03:36 AM
Dec-14-2021 12:58 AM
Dec-13-2021 09:25 PM
Dec-13-2021 06:03 PM
Dec-13-2021 02:50 PM
bgum wrote:
When I was in school I worked at a full service filling station part-time. Customer came in and wanted a quart of antifreeze added. I caught one of my co-workers just before he added it to the crankcase oil. After that he wasn't allowed to raise a hood. He did learn how to clean the Grease bay, restrooms, and wash bay.
Dec-13-2021 02:31 PM
Dec-13-2021 02:02 PM
Dec-13-2021 01:20 PM
