Oct-02-2013 08:31 AM
Oct-08-2013 09:02 AM
Oct-03-2013 08:25 PM
deltabravo wrote:diver110 wrote:deltabravo wrote:
Did you mean to say LML? (2011 and newer)
Yeah, but isn't it actually LMM? 🙂
LMM is 2008-2010. Mine is an LMM
LML is 2011+
http://www.dieselplace.com/forum/63-gm-diesel-engines/
Oct-03-2013 07:44 PM
Oct-03-2013 05:06 PM
I gather the LLM's are quieter,
Oct-03-2013 04:35 PM
Oct-03-2013 02:53 PM
Oct-03-2013 01:28 PM
elkhornsun wrote:
There is one manufacturer that makes a two part molded fiberglass camper that in theory should be exceptionally weather tight but in reality is more prone to letting water inside.
Oct-03-2013 12:10 PM
Oct-03-2013 11:15 AM
Oct-03-2013 07:07 AM
Oct-03-2013 06:57 AM
Oct-03-2013 06:30 AM
Oct-03-2013 03:35 AM
Oct-02-2013 08:00 PM
Led 67 wrote:
OK I am stepping into this with a rather obvious yet as unaddressed issue... Watch your axle rating with most modifications you can and will be safe however if you exceed the axle "Not the suspension boys" you can break your axle and then all the modifications that were done are useles so you may be wanting to consider axle ratings also. Good Luck
