Battery operated air compressor --small
MarkTwain
Looking for a good, study and dependable small air compressor to fill air bag on my 5th wheel hitch.
thanks
17 REPLIES 17
_DJ_1
billsnp5 wrote:
For airbags and bike tires I have one of the 19V handheld Craftsman compressor. It airs up the bags or a bike tire quickly. They are fairly cheap and I carry a few of the 19V tools and a charger with me.
This one probably fits your request the best for a small battery operated air compressor. I also carry one along with drill, batts and charger. Works well.
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
rickeoni
I just bought a viair 300. Fills up my 19.5's effortlessly, nice and quiet also.
2008 F450
2007 Adventurer 85WS
2012 Haulmark "The Garage"
2016 Outdoors RV Glacier Peak 26 RKS
jefe_4x4
All good advice. This is one area you need to examine the duty cycle of each product. I was suckered into buying a cheap, china freight, high volume air compressor-twice. I am such a fool. The first one failed on the first trip. I used wet rags on the cylinder head to try mitigating the extreme heat the product produced. The second replacement version lasted one tire before it blew the fuse and stopped working entirely. I could find no replacement fuses for it. (35amp) Granted, they were big volume tires. (375x55R16's on 12" wide rims. Lots of volume meaning the pump runs into trouble with heat buildup.)
This is one area where you do not want to try to cheap-out. Via Aire has a good reputation. Luckily, for me, all these small 12v compressors were only a backup position against the CO2 tank. For years I've used various sizes of CO2 tanks( 5#, 10#, 20#) for blowing up tires after being at low pressure in loose sand or bottomless snow. For my conditions, this works the best. Day after day at Moab deflating and reinflating the tires at the trailhead. The trouble is I have to blow up 4 big volume tires, one after the other. Therein lies the problem. Duty cycle. I can get about 30 big tires inflated from 10 pounds or so up to running pressure, one after the other, and fairly fast; faster than any compressor can. It's enough to last 7 days at Moab. Lots of choices here. Choose well.
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
languiduck
Viair is probably the best, but I've been using this one for many years of trouble free service so far. And it will still easily pump up tires to over 80psi in just a couple minutes. Use it on my Jeep tires, airbags, mattresses, truck tires, etc.
http://www.amazon.com/Smittybilt-2781-5-65-Universal-Compressor/dp/B004K25GMG/ref=sr_1_2?ie=UTF8&qid...
2006 F250
Palomino Bronco 800
billsnp5
http://www.sears.com/craftsman-c3-19.2-volt-cordless-inflator/p-00911586000P
2021 Host Cascade
2020 Ram Laramie 3500 DRW 4X4 Crew Cab Diesel
2013 Phoenix 721 Bass Boat
billsnp5
2021 Host Cascade
Wanderin_fool
I have a Bon-Aire and its awesome. Cheap and has worked on car tires,ATV tires, air bags.
Duramax/Lance 835
KTM/Arctic Cats
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Other Forums:
Thedieselplace.com ( chevsforever)
KTMtalk.com (xrcrasher)
Pontoonboating.com (Lounge Lizard)
Arcticchat.com (400crasher)
narcodog
I have a Viair and that's the one I would go with. You may just want to inflate an air bag today but tomorrow it may be a tire for yourself or someone else.
Moomba2002
Extreme Outback Products. Great products and service.
2017 Ford F350 Super Duty 4x4
Demco Hijacker Autoslide 18k hitch
2017 Columbus 383FB
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
2003 Arctic Fox 1150 loaded except solor
MarkTwain
RoyB wrote:
For me the Q Industries MV50 Portable 12VDC Portable Tankless Air Compressors (AMAZON) works just fine. I can air-up my trailer and truck tires and also use it for blowing out my water lines in the trailer when the temps drop below freezing...
I have used this model from way back in my Jeep/tent camping days.. Stores easy in its own carry bag and fits under my truck back seat area. I can sit this on my dropped tail gate of the truck and connect directly into the trailer battery bank terminals. The long hose reaches everything from this spot.
I use this adapter from AMAZON to connect to the city water port to blow out my water lines in the trailer and then fill the P-TRAPS with RV pink stuff. With the tankless compressor the pressure is slow to build-up which allows to get to the spigots everywhere to drain the water out without fear of over pressure on the lines.
Great small footprint items to have around for my off-road trailer...
Works great with my OFF-ROAD POPUP trailer and F150 TRUCK Tires. I can air up 65-80LBS real easy... The MAX air is rated at 150lbs. As old as mine is now I doubt I could ever get that much haha...
Roy Ken
Thanks for the info. How long is the electrical cord? I need about 20'.
thanks
Kayteg1
I had several of those cheap 12V pumps and they usually are good for couple of 35psi tire inflations.
Than few years ago I bought Firestone pump design for air helper bags.
I made it portable and used on 90 psi trailer tires and air bags at least 20 times and is still pumps up.
bedrocker
Roy B I have the same one works great
I have had it for over 5 yrs ๐Ÿ™‚
RoyB
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
jmcgsd
I carry an air tank. Works quickly, doesn't need a 12v connection and has enough volume to at least partially fill a truck tire in a pinch.
As a CG Host at a National Park site with no hookups I was popular with the air mattress set last summer too. ๐Ÿ™‚
'09 Pacific Coachworks Tango 276RBS
95 Lance 880 Truck Camper
'91 F350 Dually 2WD CC 7.5L (76K Original miles!)
AirLift Bags, Reese Titan hitch, Rancho 9000X
