Mar-07-2014 05:10 AM
Mar-07-2014 02:40 PM
tenbear wrote:
Trailers have a break away emergency brake wired off the battery. You should not place the battery cut off switch where the voltage to this emergency brake is cut off. That precludes putting the cut off in the negative lead.
Mar-07-2014 01:39 PM
Mar-07-2014 09:22 AM
shasta24 wrote:What makes even more sense is to ensure there's no big draw on the batteries when you throw that switch.
I was told by an rv pro to put the cut off switch on the negative side so it doesn't spark. Does this make sense?
Mar-07-2014 09:09 AM
shasta24 wrote:Either location, (-) or (+) will interrupt the circuit. A spark might happen on either polarity, it shouldn't be an issue as long as you have the battery box free of fumes.
Mar-07-2014 08:52 AM
Mar-07-2014 08:37 AM
Mar-07-2014 07:59 AM
Mar-07-2014 06:41 AM
Mar-07-2014 06:36 AM
Mar-07-2014 06:12 AM
Mar-07-2014 05:53 AM
Mar-07-2014 05:17 AM
Mar-07-2014 05:14 AM
