Jul-08-2017 02:14 PM
Jul-11-2017 06:31 AM
Jul-08-2017 08:36 PM
Jul-08-2017 06:48 PM
Jul-08-2017 06:39 PM
Deano_1 wrote:
I didn't put a ton of grease in and around everything, but I was careful make sure both bearings were properly coated.
Deano
Jul-08-2017 06:32 PM
Jul-08-2017 06:29 PM
Jul-08-2017 06:26 PM
Deano_1 wrote:
I'm not sure they're "fully jamed". Like I said I pumped maybe 10 or 15 pumps in. There was certainly a lot more grease when I took everything apart than when I put it back together. My plan is tomorrow I'm going to take a 10-15 mile drive and get everything heated up, get it back home and pull the wheel and hub off and check everything out. Probably overkill, but I'd rather do that they drive 250 miles next Friday and have a problem.
Thanks for all of the suggestion.
Deano
Jul-08-2017 06:13 PM
Jul-08-2017 04:04 PM
Jul-08-2017 04:03 PM
Jul-08-2017 03:32 PM
Deano_1 wrote:
Not sure what you mean by had packed correctly. I did was to pack/grease the two bearings. Beyond packing the bearings, what do you mean?
Is there a potential problem if I adds more into the fitting?
Thanks
Jul-08-2017 03:31 PM
Jul-08-2017 03:30 PM
Deano_1 wrote:If you just swished some grease on that could be insufficient. If you forced grease into the rollers so it oozed out in all directions then you are good and done.
Thanks
Jul-08-2017 03:08 PM
